Using a range type in survey123 connect
2179
09-04-2019 02:02 PM
by Anonymous User
Not applicable
I was just curious if anyone has any information about using the "range" type in the connect xls form? I have tried it out and it seems to work, but I cannot figure out a war to set some parameters. I need to set a range of 0-5 and I have tried the constraint column and this did not work. The xls.org site shows setting a constraint in a Parameters column, but that does not exist in the Connect form.
by Anonymous User
Not applicable
Hi Doug,
The range question type will be supported in version 3.6, it is not currently supported in 3.5 although may work in some cases. You can find out more currently on EAC where the beta and release candidates versions of Survey123 and documentation are provided. Once 3.6 is released, the online documentation will be updated with support for the range question.
Phil.
