Survey123 Custom URL and Relevant Condition Not Showing TextBox
1122
08-30-2019 11:23 AM
joerodmey
Having issue with my Survey123 web form that isn't putting in the data being passed via the URL. This particular field is of text type and is only visible sometimes as there is a relevant condition attached to it. When I try passing in data to this field nothing populates even when it is visible in the form. I've verified that my syntax in the custom URL is correct.
Any ideas why this would be the case?
joerodmey
Any help with this James TedrickIsmael Chivite  Philip WilsonJohnathan Hasthorpe
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
Can you provide a sample of the form and URL parameters being used to open the form?
joerodmey
Hi James,
A sample of the URL:
https://survey123.arcgis.com/share/xyz123?field:ID=682&field:Floor=Main_Floor&field:Name=Joe&field:R...
For example the name isn't being passed into the field Worker even when I break it down and only pass in that field. I've used this format the whole way through with tons of other fields I have but this is the first time such a problem has occurred. This Worker field has a condition based on a select one question.
