Error 001600 when trying to Alter Field Name and Alias
1657
08-30-2019 11:09 AM
APaulsen
How do you overcome this issue in ArcGIS Pro.  There is no data associated with this feature class at the moment.  I want to change a field name and alias to something else.  I am also not able to delete it.  ??
DanPatterson_Retired
What is the field name?
The field name you attempted to alter may be a reserved field name, a required field, or contain invalid characters
Zdenekprocner
A schema lock was applied to the geodatabase.  .... layer is lock. ....For your success remove the locks
