Beta - Survey123 Connect Create geotrace from coordinates
2089
9
08-28-2019 02:24 PM
ChrisBlinn1
I was looking to create a line (and eventually maybe a polyline) using coordinates from geopoints.
I came across this post and thought it would be as simple as calculating the value for the geotrace like so:
concat(${starty}, ' ', ${startx}, ';', ${endy}, ' ', ${endx})
But I keep getting errors, and I have tried multiple iterations.
Knowing geotrace inputs are still in beta I wasn't sure if I was heading down a dead end road, but that post gave me some promise.
Is there something wrong with my syntax, or as I mentioned, am I just trying to do something not yet supported?
Shwu-jingJeng
Hi Chris,
Are you a member of survey123 early adopter community program? We do have document showing how to capture line/polygon with calculation and also provide a sample of the form for beta testers to try.
I'd recommend you to join our early adopter community program to access the beta features.
Shwu-Jing
ChrisBlinn1
Thanks, Shwu-jing.  I am a member of the early adopter program, but neglected to read through the forums.  I tracked down the ConstructingLinesAndPolygons.zip.  I will attach it here for others.
PaulSolsrud
Thanks for this. I was able to get the point collection to work, but that's old news. I still can't get the polygon collection to work using either my own, or your zip file data. When I click on the map in Survey123 connect, it simply doesn't do anything.
Is there any more documentation on the geotrace functions?
by Anonymous User
Not applicable
It might depend on a few things -
What type of device are you using to collect the data?
Are you using an external GPS?
Have you applied the setting within the body::esri:style for the method of capture (method=vertex for GPS enabled capture)?
How is your form setup; do you have multiple questions for multiple features? I have noticed that if you build a form with two types of geometries within the main form; that the second will not work unless it is placed into a repeat. This is due to the underlying structure of how Survey123 works with a Hosted Feature service and requiring a primary feature layer to write the data into.
I have a survey form that uses a geoshape as the main feature, but then also have related 2 separate points (one for photos and another for tabular data), a separate polygon, and two related tables for each polygon captured. works great.
JamesTedrick
Esri Esteemed Contributor
Hi Paul,
With 3.6 released, the documentation has been updated to explain geotrace and geoshape collection: Geotrace and geoshape—Survey123 for ArcGIS | Documentation .  You may  may also want to review the blog post on polygon/line collection, Survey123 Tricks of the Trade: Lines and Polygons
PaulSolsrud
Thank you, those links helped. I updated my Survey 123 Connect app, and now
I got it working.
Paul Solsrud, PMP
Product Manager | Cooperative Network Services, LLC
14 Main St SW | P.O. Box J | Menahga, MN 56464
320.250.1296 (Direct) | 218.564.3000 (Main Office)
paul.solsrud@cooperative-networks.com
TylerDeBruin
New Contributor III
Thanks for the helpful articles. I was reading through them and I still have an additional question. Is there a way to transfer line data from arcgis online to a survey123 geotrace via a dynamic hyperlink? I would be nice to select a line in arcgis online and have it autopopulate the line in survey123.
JamesTedrick
Hi Tyler,
Yes, you can specify the value as a sequence of Y X values separated by a semi-colon:
Y1 X1;Y2 X2;Y3 X3;...
I plan to publish a blog soon showing an Arcade script that provides this.
TylerDeBruin
New Contributor III
Thanks a lot James, that is very helpful. I look forward to your blog on the subject.
