Questions on editing existing surveys
547
08-23-2019 05:54 PM
JeffHyder
New Contributor III
I have survey that I created which is a permit application. I want to know if I could add additional questions that are hidden and that can only be answered or edited by us and once we edit them they could be visible in a popup showing the status in a web map  after the inspection as been completed.
Joe Contractor enters an application.. a survey
Joe Contractor calls for inspection.. we edit survey stating Contractor has called in ... ready for inspection
Assign survey to inspector to inspect he edits survey with results updates survey
Joe Contractor can view map click on his point on the map representing his location and sees popup with updated inspection status
JamesTedrick
Esri Esteemed Contributor
Hi Jeff,
Yes this should be possible using Survey123 Connect. You can add additional questions, including hidden ones to a survey.
