I'm looking for a geodatabase design or example database for fields in a agriculture research farm
1166
08-23-2019 02:17 PM
KenBates1
Our school has a research farm with defined field boundaries that we are about to update and catalog.  What I would like to see a data model or example of how to use that to track use, changes in boundary, subsetting of boundaries through time.
LanceCole
MVP Regular Contributor
Ken,
Here are a couple of links on AGOL as example only.  You can search for “agriculture” once on the site and there are hundreds of other examples that may be closer to what you are looking for.  Some of the underlying data in other examples may contain what you are looking for specifically.
https://www.arcgis.com/home/item.html?id=2350a7745702402fb9ecdc507541dac4
https://www.arcgis.com/home/item.html?id=573a31c8e47948a0abfa54d3065078c1
KenBates1
Thanks!
Sent from my iPhone
KenBates1
Thanks Lance but neither of these address my needs..which I may not have stated well.
My need is a data structure that captures boundaries (fields) and maintains them thru time and area changes (being broken into smaller areas for research but still part of the whole).
The one data design that comes to mind are HUCS…but was hoping someone had tackled this in a farm research facility..
Ken Bates
GIS Extension Specialist
Kentucky State University
College of Agriculture, Communities and the Environment
400 East Main Street
Cooperative Extension Building, Suite 107
Frankfort, KY 40601
502-597-7016
www.kysu.edu<http://www.kysu.edu/land_grant/gis>
(on ascertaining the true shape of the earth)...the answer lies partly with the fact that eighteenth-century scientists, the French in particular, seldom did things simply if an absurdly demanding alternative was available.....Bourguer and La Condamine thus spent nearly a decade working toward a result they didn't wish to find only to learn that they weren't even the first to find it. Listlessly they completed their survey,...and still not speaking (for almost 9 years), they returned to the coast and took separate ships home....from "A Short History of Nearly Everything" Bill Bryson
by Anonymous User
Not applicable
Hi Ken, to help find you some more help on this I've moved this question to the Geodatabase space where hopefully you'll find some additional help from community members with expertise in this area.
