How to change cursor on the map when using SketchViewModel
3214
08-22-2019 01:35 PM
BradBarnell
Is there any way to change the mouse cursor on the map after activating the SketchViewModel in the latest version of the javascript API?  I tried doing it with css with no luck.
viewDiv.style.cursor = "default";
BenElan
Esri Alum
In vanilla JavaScript it would be
document.getElementById("viewDiv").style.cursor = "default";
If that doesn't work you could try using jQuery
$('#viewDiv').css( 'cursor', 'default' );‍‍‍‍‍‍
jQuery CDN:
<script src="https://code.jquery.com/jquery-3.4.1.min.js"
  integrity="sha256-CSXorXvZcTkaix6Yvo6HppcZGetbYMGWSFlBw8HfCJo="
  crossorigin="anonymous"></script>‍‍‍‍‍‍
BradBarnell
@Ben Elan - ESRI support says this is not possible without downloading the API javascript and hacking it, so I have given up on doing this.
IvanGatchik
Here is a bit of a sledgehammer way to force the issue (in typescript, but it should be even simpler in plain javascript):
            // set the mapview surface cursor to default
            const mapContainer = document.getElementById("map-container");
            if (mapContainer{
                for (let i = 0; i < mapContainer.childNodes.length; i++{
                    const rootElement = mapContainer.childNodes[ias Element;
                    if ((mapContainer.childNodes[ias Element).classList.contains("esri-view-root")) {
                        for (let j = 0; j < rootElement.childNodes.length; j++{
                            const viewSurface = rootElement.childNodes[jas Element;
                            if (viewSurface.classList.contains("esri-view-surface")) {
                                (viewSurface as HTMLElement).style.cursor = "auto";
and to restore your crosshair sketch cursor:
            // set the mapview surface cursor to crosshair
            if (mapContainer{
                                (viewSurface as HTMLElement).style.cursor = "crosshair";
