Date labels on Time Slider Widget don't work when you use "setInterval" method
5108
08-18-2019 10:48 PM
KokiKUNIHARA
I'm using Time Slider Widget and I've found out there is a minor defect in Time Slider Widget.
When I used Time Slider Widget and "setInterval" method, date labels on the widget kept getting off to the left, which I don't think is how it works.
It's hard to explain this issue in writing, so I've attached a video and  sample code to make it as clear as possible to you.
I would appreciate it if you could take a look at it.
I know the esri/widgets/TimeSlider class is currently on a beta release state, but I'd like to notify this issue and I hope it will be fixed.
TimeSlider | ArcGIS API for JavaScript 4.12
Tags (1)
UndralBatsukh
Hi there,
This issue will be fixed at version 4.13.
-Undral
UndralBatsukh
Hi there,
Thank you so much for reporting this issue. I was able to reproduce the issue. TimeSlider's fullTimeExtent is not being set properly at runtime once it is set first time. We will get this issue fixed hopefully at our next release.
-Undral
UndralBatsukh
Hi there,
-Undral
