query expression
1491
08-18-2019 06:23 AM
anjelinaponkerat
Hi
I set a query expression by AND operation, but my query can not do any action an get result !
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>QueryTask - 4.12</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#optionsDiv {
background-color: dimgray;
color: white;
padding: 10px;
width: 350px;
.esri-popup .esri-popup-header .esri-title {
font-size: 18px;
font-weight: bolder;
.esri-popup .esri-popup-body .esri-popup-content {
font-size: 14px;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.12/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/GraphicsLayer",
"esri/tasks/QueryTask",
"esri/tasks/support/Query"
], function(Map, SceneView, GraphicsLayer, QueryTask, Query) {
// URL to feature service containing points representing the 50
// most prominent peaks in the U.S.
var peaksUrl =
"https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Prominent_Peaks_US/FeatureServer/0";
// Define the popup content for each result
var popupTemplate = {
// autocasts as new PopupTemplate()
title: "{MTN_PEAK}, {STATE}",
fieldInfos: [
fieldName: "ELEV_ft",
label: "Elevation (feet)",
format: {
places: 0,
digitSeperator: true
fieldName: "ELEV_m",
label: "Elevation (meters)",
format: {
places: 0,
fieldName: "PROMINENCE_ft",
label: "Prominence (feet)",
format: {
places: 0,
fieldName: "PROMINENCE_m",
label: "Prominence (meters)",
format: {
places: 0,
fieldName: "ISOLATION_mi",
label: "Isolation (miles)",
format: {
places: 0,
fieldName: "ISOLATION_km",
label: "Isolation (km)",
format: {
places: 0,
content:
"<b><a href='https://en.wikipedia.org/wiki/Topographic_prominence'>Prominence:</a>" +
"</b> {PROMINENCE_ft} ft ({PROMINENCE_m} m)" +
"<br><b>Prominence Rank:</b> {RANK}" +
"<br><b>Elevation:</b> {ELEV_ft} ft ({ELEV_m} m)" +
"<br><b><a href='https://en.wikipedia.org/wiki/Topographic_isolation'>Isolation:</a>" +
"</b> {ISOLATION_mi} mi ({ISOLATION_km} km)"
var mtnSymbol = {
type: "point-3d", // autocasts as new PointSymbol3D()
symbolLayers: [
type: "object", // autocasts as new ObjectSymbol3DLayer()
resource: {
primitive: "cone"
// Create graphics layer and symbol to use for displaying the results of query
var resultsLayer = new GraphicsLayer();
* Point QueryTask to URL of feature service
var qTask = new QueryTask({
url: peaksUrl
* Set the query parameters to always return geometry and all fields.
* Returning geometry allows us to display results on the map/view
var params = new Query({
returnGeometry: true,
outFields: ["*"]
var map = new Map({
basemap: "osm",
layers: [resultsLayer] // add graphics layer to the map
var view = new SceneView({
map: map,
container: "viewDiv",
center: [-100, 38],
zoom: 4,
popup: {
dockEnabled: true,
dockOptions: {
position: "top-right",
breakpoint: false
// Call doQuery() each time the button is clicked
view.when(function() {
view.ui.add("optionsDiv", "bottom-right");
document.getElementById("doBtn").addEventListener("click", doQuery);
var attributeName = document.getElementById("attSelect");
var expressionSign = document.getElementById("signSelect");
var value = document.getElementById("valSelect");
var attributeName2 = document.getElementById("attSelect2");
var expressionSign2 = document.getElementById("signSelect2");
var value2 = document.getElementById("valSelect2");
// Executes each time the button is clicked
function doQuery() {
// Clear the results from a previous query
resultsLayer.removeAll();
* Set the where clause for the query. This can be any valid SQL expression.
* In this case the inputs from the three drop down menus are used to build
* the query. For example, if "Elevation", "is greater than", and "10,000 ft"
* are selected, then the following SQL where clause is built here:
* params.where = "ELEV_ft > 10000";
* ELEV_ft is the field name for Elevation and is assigned to the value of the
* select option in the HTML below. Other operators such as AND, OR, LIKE, etc
* may also be used here.
params.where =
(attributeName.value + expressionSign.value + value.value) + "AND" + (attributeName2.value + expressionSign2.value + value2.value) ;
// executes the query and calls getResults() once the promise is resolved
// promiseRejected() is called if the promise is rejected
qTask
.execute(params)
.then(getResults)
.catch(promiseRejected);
// Called each time the promise is resolved
function getResults(response) {
// Loop through each of the results and assign a symbol and PopupTemplate
// to each so they may be visualized on the map
var peakResults = response.features.map(function(feature) {
// Sets the symbol of each resulting feature to a cone with a
// fixed color and width. The height is based on the mountain's elevation
feature.symbol = {
symbolLayers: [
material: {
color: "green"
resource: {
primitive: "cone"
width: 100000,
height: feature.attributes.ELEV_m * 100
feature.popupTemplate = popupTemplate;
return feature;
resultsLayer.addMany(peakResults);
// animate to the results after they are added to the map
view.goTo(peakResults).then(function() {
view.popup.open({
features: peakResults,
featureMenuOpen: true,
updateLocationEnabled: true
// print the number of results returned to the user
document.getElementById("printResults").innerHTML =
peakResults.length + " results found!";
// Called each time the promise is rejected
function promiseRejected(error) {
console.error("Promise rejected: ", error.message);
</script>
</head>
<body>
<div id="viewDiv"></div>
<div class="esri-widget" id="optionsDiv">
<h2>Prominent Peaks in the U.S.</h2>
<select class="esri-widget" id="attSelect">
<option value="ELEV_ft">Elevation</option>
<option value="PROMINENCE_ft" selected>Prominence</option>
</select>
<select class="esri-widget" id="signSelect">
<option value=">">is greater than</option>
<option value="<">is less than</option>
<option value="=">is equal to</option>
</select>
<select class="esri-widget" id="valSelect">
<option value="800">1,000 ft</option>
<option value="850">5,000 ft</option>
<option value="10000">10,000 ft</option>
<option value="15000">15,000 ft</option>
<option value="20000">20,000 ft</option>
</select>
<select class="esri-widget" id="attSelect2">
</select>
<select class="esri-widget" id="signSelect2">
</select>
<select class="esri-widget" id="valSelect2">
<option value="850">1,000 ft</option>
<option value="950">5,000 ft</option>
</select>
<br />
<br />
<button class="esri-widget" id="doBtn">Do Query</button> <br />
<p><span id="printResults"></span></p>
</div>
</body>
</html>
RobertScheitlin__GISP
Yep that should work.
Anjelina,
   You where statement is a not proper. You can not have a "PROMINENCE_ft>800ANDPROMINENCE_ft>850". Where is you required spacing before and after the "AND"?
anjelinaponkerat
Is this true?:
params.where =
(attributeName.value + expressionSign.value + value.value)+" AND "+(attributeName2.value + expressionSign2.value + value2.value) ;
