'Select multiple' functionality in feature reports (Survey123)
966
08-14-2019 06:55 AM
Jodie_M_Gosselin
Is there any way I can format Survey123 feature reports to list out answers to select multiple questions? Here's what I found online about this type of conditional formatting:
${select_multiple|appearance:"bullets"}
When I upload my template with this format and try to generate a report, it fails. I added my field name after the select_multiple within the brackets, is that the correct way to do this? For example:
${select_multiple speedlimit|appearance:"bullets"}
Is this the correct way to set up a conditional statement where the feature report would read something like Speed Limit: 45, 50, 60, 76?
Thanks!
MichelleWilliams1
Did you ever get an answer?
Here's the proper format for my select_multiple question, you need to add the name of the field.
If it's in the main survey
${OperationalConditions2| appearance:"bullets"}
If it's in a repeat you must add the name of the repeat first and last (on its own line)
${#Inspection}
${/Inspection}
Have a great day.
Now if I could only figure out how the change the font size of my bullets inside a repeat. That's what I am looking for.
