Default date doesn't show in web survey
2060
08-13-2019 02:13 PM
by Anonymous User
Not applicable
I authored a simple check-in survey in Connect, with a date field set to a default value of "today()". However, when I publish and open the survey in the web application, the default date doesn't appear. Is this a limitation of the Connect to Web App translation?
I've noticed this in other surveys I've authored as well, however I thought it was due to republishing a survey after making changes. I deleted my check in survey and tried publishing it again, but the same error occurred.
Thank you,
Hilary
Shwu-jingJeng
Hi Hilary,
Try to put today() under calculation field, instead of default and publish again. You should be able to see today value for your date question.
NeumanAndrew
Wouldn't that change all values to today() even if the users entered a different date? In my case, I only want to set the default value, not enforce that it's using that value.
