Cloning PictureElement
442
08-12-2019 02:42 PM
NaserTamimi
My question is about ArcPy.
It seems that PictureElement does not have a clone method. How can I clone a PictureElement then?
LukeWebb
As you discovered, I think that you cant using basic arcpy functions, but there are workarounds, such as:
  • you can replace its source
  • have image elements, that are located 'off the page', then in the code you can move them into the right location as required and away again when not needed.
  • Maybe others?
DuncanHornby
MVP Notable Contributor
Suggest you look at this page on geonet, I guess you did not find it?
