Unable to Enable Sync on Hosted Feature Service View
7167
5
08-09-2019 06:37 AM
PatrickFilyer
As suggested by the title, I am unable to enable sync on a hosted feature service view. The feature service that the view is created from has sync enabled. Whenever I click on enable sync on the view i get an error saying: "Save wasn't successful. Try again later." When I look on fiddler I just see "Error 500".
Unfortunately, I cant republish the original hosted feature service as Users have it checked out for field work. This fix was suggested to me by Esri Tech Support. I hope there is another way to fix this.
Anyone ever run into this issue?
LanceCole
Patrick,
Do you have synchronization configured on both the hosted feature layer and view?
Hosted feature layer views do not inherit synchronization settings from the hosted feature layer from which you create them. To enable synchronization on a hosted feature layer view, you must first enable it on the primary hosted feature layer. To disable synchronization on the primary hosted feature layer, you must first disable it on each dependent hosted feature layer view.
Rodriguez_Carlos__ITD_
Were you able to figure this out. We are having the same issue. We tried enabling it in AGOL and also tried forcing it using the ArcGIS API for Python. Neither of these options worked. We tried disabling sync on the parent hosted feature layer and then re-enabling and then trying to enable in the view but nothing works.
DoZ
Hello Eveyone,
I also need to enable Sync on a vie because I need to take the Layer offline.
I found this: Manage hosted feature layer editing—ArcGIS Online Help | Documentation where it is stated "You cannot enable editing or synchronization on hosted feature layer views created as a result of running the Join Features tool."
But I really need to take a Layer Offline which must be a view between 2 Hosted Features. Is there a way to create such a View without using the Join Feature tool?
Thanks you very much for any suggestions!!
DoZ
LD1
I wanted to do this as well, but found out that you cannot Enable the sync:
Alex_Moore
It may be because you need some sort of Global ID field in your data to enable sync.
Solution that worked for me (I was working with a .CSV):
--- I took the CSV into ArcGIS Pro
--- Added it into my geodatabase
--- Ran the 'Add Global ID' tool
--- Ran 'XY Table to Point' tool
--- Published the new layer to ArcGIS Online where I was able to enable sync
NOTE: at first, I simply created a hosted feature layer from my CSV and tried to enable sync, which did not work.
Associate GIS Analyst
Esri Canada
