Ctrl + Mouse click
6077
8
08-07-2019 10:25 PM
kawishabbas
Hi
I want to use Ctrl key with mouse click to get coordinates. Following snapshot is working well on mouse click, is there any way to modify this code with Ctrl key????
RobertScheitlin__GISP
Kawish,
  The ctrl key is part of the native object in your "show" object.
view.on('click', function(show){
  console.info(show.native.ctrlKey);
Kawish,
kawishabbas
Thank you Robert Scheitlin, GISP‌.
Can you solve another problem. i have added point with "Ctrl + mouse click" to map but i want to remove that point after 5 second or 3 second.
How is it possible??.
Kawish,
  Sure just add a setTimeout to the end of your code that removes the graphic.
setTimeout(function(){
  view.graphics.remove(pointGraphic);
}, 5000);‍‍‍‍‍‍
Valgenmap
Hi @RobertScheitlin__GISP
Can you please help me on this.
I'm receiving evt.native as 'undefined' while "CTRL + click" on the featurelayer here is my code,
/* eslint-disable */
import React, { useRef, useEffect } from 'react';
import MapView from '@arcgis/core/views/MapView';
import WebMap from '@arcgis/core/Map';
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
import Draw from '@arcgis/core/views/draw/Draw';
import Graphic from '@arcgis/core/Graphic';
import GraphicsLayer from '@arcgis/core/layers/GraphicsLayer';
import Point from '@arcgis/core/geometry/Point';
import MultiPoint from '@arcgis/core/geometry/Multipoint';
import Search from '@arcgis/core/widgets/Search'
import '../../assets/css/map.css';
const Map = () => {
  const mapDiv = useRef(null);
  const click_ref = useRef(null);
  useEffect(() => {
    if (mapDiv.current) {
       * Initialize application
      const pntGraphics = new GraphicsLayer();
      let renderer = {
        type: 'simple', // autocasts as new SimpleRenderer()
        symbol: {
          type: 'simple-fill', // autocasts as new SimpleFillSymbol()
          color: [255, 255, 255, 0.5],
          style: 'none',
          outline: {
            // autocasts as new SimpleLineSymbol()
            color: 'white',
            width: 2,
      let drawPnt,
        graphic,
        ctrlKey = false,
        highlight,
        statesLyrView;
      const webmap = new WebMap({
        basemap: 'streets-vector',
      const view = new MapView({
        container: mapDiv.current,
        map: webmap,
        center: [-98.43750059604514, 38.1986442207947],
        scale: 25000000,
        ui: {
          components: ['zoom', 'compass'],
      const searchWidget = new Search({
        view: view
      view.ui.add(searchWidget, "top-right");
      const stateFeatureLayer = new FeatureLayer({
        url:
          'https://services2.arcgis.com/JoecHEvChY6qFe2m/arcgis/rest/services/USA_States/FeatureServer/0',
        outFields: ['*'],
      const cityFeatureLayer = new FeatureLayer({
        url:
          'https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0',
        outFields: ['*'],
      webmap.addMany([stateFeatureLayer, cityFeatureLayer]);
      stateFeatureLayer.when(function () {
        view.whenLayerView(stateFeatureLayer).then(function (layerView) {
          statesLyrView = layerView;
      const draw = new Draw({
        view: view,
      var sym = {
        type: 'simple-marker',
        style: 'circle',
        color: [0, 255, 255, 0.6],
        outline: {
          color: [0, 255, 255, 1],
          width: 1,
      view.ui.add('point-button', 'top-left');
      const drawPoint = () => {
        console.log('in ');
        if (highlight) {
          highlight.remove();
        const action = draw.create('point');
        action.on('cursor-update', function (evt) {
          view.graphics.removeAll();
          drawPnt = new Point({
            x: evt.coordinates[0],
            y: evt.coordinates[1],
            spatialReference: view.spatialReference,
          graphic = new Graphic({
            geometry: drawPnt,
            symbol: sym,
          view.graphics.add(graphic);
          /*if (ctrlKey && !evt.native.ctrlKey) {
              draw.reset();
              selectStates();
        action.on('draw-complete', function (evt) {
          if (evt.native.ctrlKey) {
            ctrlKey = true;
          } else {
            ctrlKey = false;
            geometry: drawPnt,
            symbol: sym,
          pntGraphics.add(graphic);
            drawPoint();
          } else {
            selectStates();
        view.focus();
      function selectStates() {
        console.log('in selectstate');
      click_ref.current = drawPoint;
      //document.getElementById('point-button').onclick = drawPoint;
  return (
    <div className="mapDiv" ref={mapDiv}>
      <button
        id="point-button"
        className="esri-widget esri-widget--button esri-interactive"
        title="Select Countries"
        onClick={()=>click_ref.current()}
        <span className="esri-icon-map-pin"></span>
      </button>
    </div>
export default Map;
I'm getting error at line:128  and 143, since evt.native showing as undefined.
I'm using
"@arcgis/core""^4.19.1"
"react""^17.0.2",
@Valgenmap ,
There is no event native (just as the error is telling you) on the 'draw-complete' event. You would have to figure out how to use the view click event if you want to capture the mouse click event.
Valgenmap
Hi @RobertScheitlin__GISP,
Can you provide any idea regarding the multi-selection of the features by holding 'CTRL' and click in React-ESRI app.
Regards,
ValgenMap
NickIrwin
I'm receiving evt.native as 'undefined' while "CTRL + click" with cps test on the featurelayer here is my code,
const Map = () => {
  useEffect(() => {
      let renderer = {
        symbol: {
          style: 'none',
          outline: {
            color: 'white',
            width: 2,
      let drawPnt,
        graphic,
        ctrlKey = false,
        highlight,
        statesLyrView;
        map: webmap,
        scale: 25000000,
        ui: {
        view: view
        url:
        outFields: ['*'],
        url:
        outFields: ['*'],
        view: view,
      var sym = {
        style: 'circle',
        outline: {
          width: 1,
        console.log('in ');
        if (highlight) {
          highlight.remove();
            geometry: drawPnt,
            symbol: sym,
              draw.reset();
              selectStates();
            ctrlKey = true;
          } else {
            ctrlKey = false;
            geometry: drawPnt,
            symbol: sym,
            drawPoint();
          } else {
            selectStates();
        view.focus();
  return (
      <button
        id="point-button"
      </button>
    </div>
export default Map;
I'm using
"react""^17.0.2",
Is this code snippet working for anyone? I am not able to get it to run at all. A little noob here, please help.
@NickIrwin
In 4.13 the draw action had a native property. I am not sure when it was removed but now in 4.23 there is no native property returned in the DrawAction. I mentioned this above to vlagebmap back on ‎06-25-2021.
This is what it would look like in 4.23 (vanilla JS)
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>Select by Point</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.23/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.23/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/views/draw/Draw",
      "esri/Map",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/layers/FeatureLayer",
      "esri/geometry/Point",
      "esri/geometry/Multipoint",
      "esri/views/MapView"
    ], function (Draw, Map, Graphic, GraphicsLayer, FeatureLayer, Point, Multipoint, MapView) {
      let viewClickEvtHandler = null, viewMouseMoveEvtHandler = null;
      var renderer = {
          type: "simple", // autocasts as new SimpleRenderer()
          symbol: {
            type: "simple-fill", // autocasts as new SimpleFillSymbol()
            style: "none",
            outline: {  // autocasts as new SimpleLineSymbol()
              color: "white",
              width: 2
      const statesLyr = new FeatureLayer({
        url: 'https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2',
        renderer: renderer,
        outFields: ['*']
        url: 'https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0',
        outFields: ['*'],
      let drawPnt, graphic, ctrlKey = false, moveCtrlKey = false, highlight, statesLyrView;
      const map = new Map({
        layers: [pntGraphics, statesLyr, cityFeatureLayer]
        container: "viewDiv",
        map: map,
        scale: 25000000,
        ui: {
      statesLyr.when(function(){
        view.whenLayerView(statesLyr).then(function(layerView) {
        view: view
      var sym = {
        type: "simple-marker",
        style: "circle",
        outline: {
          width: 1
      view.ui.add("point-button", "top-left");
      document.getElementById("point-button").onclick = drawPoint;
      function drawPoint() {
        if(viewMouseMoveEvtHandler){
          viewMouseMoveEvtHandler.remove()
        if(viewClickEvtHandler){
          viewClickEvtHandler.remove()
        const action = draw.create("point");
        viewMouseMoveEvtHandler = view.on('pointer-move', (evt) => {
            moveCtrlKey = true;
          }else{
            moveCtrlKey = false;
        viewClickEvtHandler = view.on('pointer-down', (evt)=>{
            ctrlKey = true;
          }else{
            ctrlKey = false;
        if (highlight) {
          highlight.remove();
        // Give a visual feedback to users as they move the pointer over the view
        action.on("cursor-update", function (evt) {
            geometry: drawPnt,
            symbol: sym
          if(ctrlKey && !moveCtrlKey){
            draw.reset();
            selectStates();
        action.on("draw-complete", function (evt) {
            geometry: drawPnt,
            symbol: sym
          if (ctrlKey) {
            drawPoint();
          } else {
            selectStates();
        view.focus();
      function selectStates(){
        ctrlKey = false
        moveCtrlKey = false
        let mp = new Multipoint({
        let pntArray = pntGraphics.graphics.map(function(gra){
          mp.addPoint(gra.geometry);
        const query = {
          geometry: mp,
          outFields: ["*"],
          outSpatialReference: view.spatialReference,
          returnGeometry: true
        statesLyr.queryFeatures(query)
        .then(function(results){
          const graphics = results.features;
          // remove existing highlighted features
          if (highlight) {
            highlight.remove();
          // highlight query results
          highlight = statesLyrView.highlight(graphics);
          pntGraphics.removeAll();
        }).catch(function(err){
          console.error(err);
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="point-button" class="esri-widget esri-widget--button esri-interactive" title="Select Countries">
      <span class="esri-icon-map-pin"></span>
    </div>
  </div>
</body>
</html>
