Difference between Date Format on AGOL Map and embedded map on website
2129
08-07-2019 04:06 AM
BrendanCunningham1
I have a web map in AGOL where the date attribute is set to display at DD/MM/YYYY. When I test this in AGOL it works fine. However when I use the JS API V4.12 to embed the web map onto my website it reverts to the default date format, MM/DD/YYYY.
See attached.
Does the popup date format need to be forced to DD/MM/YYYY in the embedded map using JS, if so how is this achieved?
Many thanks.
BenElan
You can use a Popup Template: PopupTemplate | ArcGIS API for JavaScript 4.12
To specify a date format: FieldInfoFormat | ArcGIS API for JavaScript 4.12
Here is an example of how to create and use a popup template: ArcGIS API for JavaScript Sandbox
Noah-Sager
Formatting the popup content is a good idea.
Another thought is that it looks like you might have specified some localization in Portal/AGO? I believe this would account for the DD/MM/YYYY format. Either that or AGO is smart enough to recognize the date format of the region you are connecting from.
Set language and region—ArcGIS Online Help | ArcGIS
In the JS API app, you could try using the English (en) locale to see if the European date format persists
Localization | ArcGIS API for JavaScript 4.12
Lastly, you could construct an arcade expression in the popup to display the date in a logical format.
Date Functions | ArcGIS for Developers
BrendanCunningham1
Thanks all,
I made some headway with this approach:
<script> // set locale before JSAPI is loaded dojoConfig = { locale: "ja", parseOnLoad: true }; </script>
insofar as the date format changed... but I couldn't get the proper date DD/MM/YYYY to display.
In the end I reverted to one of the other date options in the web map "December 21 1997" and that sufficed.
It's a confusing one as it doesn't seem easy to trace to an exact cause.
Thanks for your help.
by Anonymous User
Not applicable
I think as a community we need to have something like this idea
ESRI default date JSON display format across entire suite of platforms
