How to duplicate an operations dashboard
20084
10
07-31-2019 11:32 AM
DavidHughell
How can I replicate my operations dashboard and have it linked to new data files without having to re-configure all the dependencies?
KenBuja
MVP Esteemed Contributor
After copying the Dashboard, use the "I want to..." dropdown and select "View an Item's JSON".
In the Data portion, you can edit the itemId property to point to the new data.
BrianBaldwin
I would give the AGO Assistant tool a try: ArcGIS Online Assistant
You can point to your Dashboard item and then create a copy of it.
You could also do this with all of the dependencies and then edit as you see fit.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
DavidHughell
Thanks for the quick response. However, if I just copy the dashboard the pointers will still point to the original data files. I need a way to edit the dashboard so they point to new files.
KenBuja
DavidHughell
This looks like what I need, but where do I find the “I want to …” dropdown?
BrianBaldwin
Where is the
DavidHughell
Thanks. Using AGO Assist to edit JSON code provide a whole new dimension to modifying dashboards.
NidaIbrahim
Hello Brian and all,
I followed the same steps to clone an ops dashboard but in the ArcGIS Online Assistant tool the targeted ops dashboard isn't getting highlighted I mean it can't be dragged and dropped in order to copy it - please see the photo below
How can I clone such a dashboard then? Thanks.
BrianBaldwin
This is a limitation of the tool - but there is a workaround.
If you are just looking to copy the dashboard in the same organization (I didn't test between organizations, but it should work as long as you duplicate the map and then update the JSON to point to that map).
So - what I did is to just create a new dashboard (can be blank) and then in the AGO Assistant tool, go to 'View an Item's JSON' - now, copy the JSON in the Data section - and then paste it into your 'new' dashboard. This will copy all of the configurations, etc. over.
Brownschuh
I found this approach to work ... kind of.  While it copied the dashboard over to the new environment, I still had to modify the JSON to point to the correct service id's.  But even then the dashboard needed some manual configuring in the edit mode to get it up and running 100%.
