Copy Shapefiles to Enterprise Geodatabase Feature Dataset
7775
10
07-31-2019 02:26 PM
JaredPilbeam2
Is there a way I can copy shapefiles in a directory to an Enterprise Geodatabase Feature Dataset in a stand-alone script? As a monthly update, the shapefiles would replace/update feature classes with the same names in a feature dataset.
I've attempted to copy a shapefile using an SDE connection file with arcpy.CopyFeatures. The script ran but nothing happened.
import arcpy
from arcpy import env
import os
ws = env.workspace = r'path\to\34512.shp'
out_ws = r'path\to\gissql(2).sde'
fcList = arcpy.ListFeatureClasses(ws)
for shapefile in fcList:
    out_featureclass = os.path.join(out_ws, os.path.splitext(shapefile)[0])
    arcpy.CopyFeatures_management(shapefile, out_featureclass)
LanceCole
Jared,
  1. Add the statement env.overwriteOutput = True to your code as Dan Patterson recommended.   This should allow feature classes to be overwritten.
  2. You forgot your env.workspace = r'path\to\shapefiles' statement so your ListFeatureClasses() statement is not returning anything or []
  3. Go back to your original iteration of code - you were very close.
Something like this:
import arcpy
import os
shp = r'pathto\Test\shapefiles'
gdb = r'pathto\TestFGDB.gdb'
sde = r'path\to\gissql(2).sde' #if using SDE connection string
env.workspace = shp
fcList = arcpy.ListFeatureClasses()
env.workspace = gdb #or use 'sde' for your SDE database
    in_shapefile = os.path.join(shp, shapefile)
    out_featureclass = os.path.splitext(shapefile)[0]
    print('Copying %s to %s' %(in_shapefile, out_featureclass))
    arcpy.CopyFeatures_management(in_shapefile, out_featureclass)
print("done")
A note on using a SDE connection, make sure you are using the correct connection string with the appropriate SDE or DBO level to overwrite a feature class or if need delete a feature class.  Your normal connection string may not have the appropriate level or permissions.
DanPatterson_Retired
https://pro.arcgis.com/en/pro-app/arcpy/classes/env.htm
but Copy Features doesn't seem to deal with so perhaps that is why it doesn't report an error
JoeBorgione
As Dan suggests, the env.overwriteOutput = True is not a surefire way.  I have found it to sometimes work and sometimes not, with no real pattern.
You could create a list of the shapefile names (sans the .shp extension) and a list of feature classes: loop through the list of feature classes and if the feature class name is in the shapefile list, delete the the feature class.
JaredPilbeam2
Joe,
I attempted to put together what I thought you were saying more or less. So far, I haven't got it to work. I put the error below the code. I thought I'd try deleting the feature classes in the dataset first, then copy the shapefiles into that dataset.
import arcpy
import os
#directory of shapefiles
shps = r'pathto\Test\shapefiles'
#directory of FCs in dataset
dataset = r'pathto\TestFGDB.gdb\dFIRM_2019_Effective'
#create lists for shapefiles and FCs
shpList = arcpy.ListFeatureClasses()
#iterate FC list, delete FCs, copy shapefiles to dataset
for fc in fcList:
    arcpy.Delete_management(dataset, "FEATURECLASS") #(in_data, data_type)
    arcpy.CopyFeatures_management(shpList, dataset) #(in_features, out_feature_class)
    print("done")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
line 15, in <module>
    for fc in fcList:
TypeError: 'NoneType' object is not iterable‍‍‍‍‍‍
LanceCole
Jared,
import arcpy
import os
env.workspace = shp
print("done")
JaredPilbeam2
Lance,
The CopyFeatures function failed:
ERROR 000733: Output Feature Class: Same as input Input Features
Failed to execute (CopyFeatures).
There were no errors up to that point. The print statement on your line 17 printed this:
Copying pathto\Test\shapefiles\S_BASE_INDEX.shp to S_BASE_INDEX‍
Apparently, it doesn't like that the shapefiles and the feature classes have the same names.
LanceCole
Jared,
You need to change the "pathto\Test\shapefiles" to the path of your shapefiles in line 5 of the code, for example r"C:\myshapefiles\toimport".  The same for the gdb path in line 6 needs to be set to the path and name of your GDB file, for example r"C:\myGDBs\TestFGDB.gdb".
Did you catch the second env.workspace = gdb after you populate the fcList?  This changes the enfironment from the shapefile folder to the GDB.
Also, if you can post the actual code you are currently using that would be helpful.
JaredPilbeam2
Lance Cole
Right, those paths are set right in my actual code.
Here are the files I'm testing on. Ultimately, I'm updating a feature dataset in the sql server database using a sde connection file.
Current Code:
update the feature classes in the feature dataset gisedit.DBO.dFIRM_2019_Effective
from the shapefiles in this directory:
\\gisfile\GISsources\Federal\FEMA\DFIRM\EffectiveProducts\SHP\17197C_WillCo_FIRMdb
import arcpy
import os
shp = r'\\gisfile\GISstaff\Jared\Test\shapefiles'
gdb = r'\gisfile\GISstaff\Jared\Test\TestFGDB.gdb\dFIRM_2019_Effective'
env.workspace = shp
env.workspace = gdb
    print(shapefile)
    print(in_shapefile)
    print(out_featureclass, "\n")
print("done")
LanceCole
Jared,
You have a single "\" at the start of GBD path this should be a double "\\" in line 12 of your code.
LanceCole
Jared‌,
Take a look at what your statement below is returning.  I bet it is a empty set [].
Try using the variation below and see if you get a list of shapefiles returned from the folder path.
Also, make sure you are just pointing to your shapefile folder path and not a specific shapefile.
ws = env.workspace = r'path\to\shapefiles'
