List name not in choices sheet?
10251
9
07-31-2019 07:55 AM
APaulsen
I keep getting the error stating my list name is not in the choices sheet when it is.  How do I fix this bug?
HerveyLee
I took a closer look at your screenshot and what you are trying to do.  You don't need a primary key / foreign key for your related table when using the begin repeat function.  Survey123 uses the GlobalID that is built into the application and it will show up once you publish the survey.
IngridAldridge1
It is the square brackets around your list name.  A select_one should look like this select_one Status.  You will want to remove the square brackets from all of your lists.
KassandraRodriguez
How you gonna diss my boys when you're not even doing it right??
APaulsen
I tried that.  It still didn't work.  So yes, I will continue to diss your boys.
KassandraRodriguez
You can't have the same field names under "name"
APaulsen
How do you handle related records then?  It was created from pulling in our Featured Service.  They are all related to the LocationID field?
HerveyLee
Are you trying to create a related records or do you have an existing related table?
APaulsen
These tables exist.
HerveyLee
You can use the look up table if these are static tables or create the relationship from ArcGIS Online once you have completed your Survey123 form.
It would be good if you had your original message fyi.
HerveyLee
