How to include ObjectID in MS Word Report Template?
1221
5
07-26-2019 04:11 AM
AdminAccount2
Occasional Contributor II
Is there a way to include the feature's ObjectID in the MS Word tempate used for generating a report?
${ObjectID} does not seem to work. Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Keith,
You may need to check the precise name of the Object ID field.  For example, the field name or a survey published by Survey123 is objectid (all lower case), though the alias is 'ObjectID'.  Therefore, ${objectid} should work in a template.
RobertBorchert
Frequent Contributor III
Create a new attribute and populate it with ObjectID before generating the report
AdminAccount2
Yes, of course I could do that, but that's not ideal. There's lot's of other hidden fields in there as well that I'd like to know how to access if there's a way to do that without duplicating all those with new fields just so I can print them.
My question remains - Is there a way to access these hidden field types like ObjectID using the correct syntax in the Word template?
RobertBorchert
Access the Database via MS Access.  However does not work with File Geodatabase
JamesTedrick
Hi Keith,
AdminAccount2
Thanks very much James, that worked!
