Credit usage reports per user using the Python API
3525
5
07-26-2019 11:02 AM
PeterGamberg1
Is it possible to return credit usage reports for each user in an Arcgis Online organization using the Python API? And if so, can it be returned for a specific period of time?
The credit manager class just returns the credit usage for the entire organization.
Tags (1)
MehdiPira1
Hi Peter Gamberg‌,
you can use the following code to check the credits availability for each user:
#Checking credits assigned and available to a user
api_acc = gis.users.get('USERNAME')
"""When you turn on credit budgeting (using the enable() method),
the User object gets additional properties to
indicate the assignedCredits and remaining avialableCredits.
Thus, you can verify as shown below:"""
api_acc.assignedCredits
api_acc.availableCredits
"""As the user continues to use the credits, the availableCredits
property can be used to check how much is available for that account.
If a user does not have a limit set, then the total available credits
in the org become their available credits. The account shown below as
not custom limit, hence, it inherits the org's total limit.‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍"""
by Anonymous User
Not applicable
I have added an idea for this as I was just trying to do this also. Please upvote it here!
Per_Åke_MattiasWallin
Use gis.admin.usage_reports.users().  See the sample @ https://community.esri.com/thread/241589-user-credit-usage?start=0&tstart=0
LindseyDanforth_Boulder
I have tried using gis.admin.usage_reports.users() and I get strange results. I get a smaller list than what it in our organization and I get lots of names outside of our organization. I can't figure out why its returning such an odd list.
MJBiazar
Hi @PeterGamberg1 I know this is an old post but I just wanted to share some info for reference. To create a credit report for users in your ArcGIS Online organization you can create a credit report in ArcGIS Online or similarly in ArcGIS API for Python using gis.admin.usage_reports.credit. You can specify the start time or the timeframe for your report if you need to:
credit(start_time=Nonetime_frame='week'export=False)
  • start_time: optional datetime, the time to step back from. If None, the current time is used.
  • time_frame: >optional string, is the timeframe report to create. Allowed values: today, week (default), 14days, 30days, 60days, 90days, 6months, year
  • export: optional boolean, if True, a csv is generated from the request. If False, a Panda’s dataframe is returned
For more details, please see our documentation:
https://developers.arcgis.com/python/api-reference/arcgis.gis.admin.html#agolusagereports
Best,
MJ
