URL Encoding
2391
07-25-2019 06:11 AM
AbdelrahmanAbdelrazek
Hello everyone,
I need to send an image using  XMLHttpRequest
and for that the  image data needs to be encoded, in javascript  this function FileReader.readAsDataURL() does this perfectly, but i'm not able to do so using QML.
I'm only able to read the image as binary values like this "\xFF\xD8\xFF....etc"
Could you please let me know how i can achieve this using ArcGIS Runtime Qt SDK QML.
Thanks in advance.
Tags (3)
LucasDanzinger
Esri Frequent Contributor
The Runtime API doesn't have any utilities to read images like this.
Adding AppStudio for ArcGIS‌ to see if they have any suggestions.
StephenQuan1
If you're using AppStudio for ArcGIS, there are several ways for working with images and uploading.
1. NetworkRequest has built in support for multipart/form-data if it detects a file upload in the request (similar to Unix curl command).
NetworkRequest {
    method: "POST"
    url: "https://some.end.point"
networkRequest.send( {
    f: "pjson",
    file: networkRequest.uploadPrefix + "myimage.png"
This is the best method, because (a) your application logic is simple, (b) the file is not loaded into memory, but streamed in blocks directly from file to the internet, allow one to upload very large files, (c) you needn't worry about setting your headers correctly for a multipart/form-data upload, this is done for you automatically.
2. We have File and BinaryData object for reading a file and converting it to another format, e.g. base64 encoding
Hi Stephen,
Thanks for your response.
you mentioned that the NetworkRequest detects a file in the request,
Is this happens because in the body object you added a file property, if so what if the object is complex and has more properties not only file and f
and the property name not file --data instead.
ex:
f:json,
attachments:{
   adds:[
                  data:networkRequest.uploadPrefix+"myimage.png"
Will the NetworkRequest still going to detect that a file in the request and set the headers to "multipart/form-data"
Also i tried to use Binarydata several times, but no luck till now to convert the image to (URL Encoded format).
the following is example of an image after reading its data as URL encoded format, and this allows me to send it using  XMLHttpRequest  and NetworkRequest
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAAABHNCSVQICAgIfAhkiAAAAHFJREFUWIXt1jsKgDAQRdF7xY25cpcWC60kioI6Fm/ahHBCMh+BRmGMnAgEWnvPpzK8dvrFCCCAcoD8og4c5Lr6WB3Q3l1TBwLYPuF3YS1gn1HphgEEEABcKERrGy0E3B0HFJg7C1N/f/kTBBBA+Vi+AMkgFEvBPD17AAAAAElFTkSuQmCC
If you copy and paste the previous value on the browser, an image will be shown.
Could you please let me know if there is a way that allows me to convert the image data into that format.
PhilPonce
Hi Stephan - I know this is old but I'm struggling with how to upload camera images to a server.  My preference would be to use a custom web service that can consume FormData via HTTPRequest since I then have ultimate control once there (I do this already via JavaScript).  The problem is I can't get figure out  "FormData" in QT QML.  I'm able to use NetworkRequest and can get the data to ArcGIS Online, but don't know what I can do with it once it's there.
Any guidance would be appreciated.
