Consistent numbering of repeat items
770
07-23-2019 02:59 AM
deleted-user--2hDb5YTmQS1
There are already some threads on how to number repeat items (e. g. How to assign each repeat group within a repeat a number label).
The proposed solution, using the once(count()) combination, seems to do the trick, but it cannot guarantee a consistent numbering of the repeat items. When, in a first instance, I create three items within a repeat (numbers #1, #2, #3) and then delete the first item (#1), the two remaining items still have numbers #2 and #3 (which is okay). Now, when I create another item (actually number #4) it also gets number #3 leaving me with two items that are numbered #3. (Maybe this is what James meant by noting '...that this does not update if a repeat is deleted mid-way through completing the form').
Is there any other way to consistently number all items in a repeat question, taking intp account that items might get deleted?
Thank you very much, best regards,
Jürgen
DougBrowning
MVP Esteemed Contributor
This may have came from my post.  I use it a lot but it never came up!
Now that I think about it maybe once(max() + 1) would work.  You have given me something to consider here.
Hi Doug,
Thank you for your answer. Although this new approach with the max() function seems reasonable, I don't get it working. Did you find out how to do the trick?
Thanks, Jürgen
DougBrowning
max only works outside the repeat if I remember right.  So you need a hidden field outside the repeat with max in it.
