Click a point feature that opens a URL in a browser
3744
7
07-16-2019 07:36 AM
MarquesMunson1
I am creating an application using JP 4.12 and I would like for the application to point to an URL within the attribute table of a feature layer when a user clicks on a point feature. I came across the following post and I tried the following code but it does not seem to work.
  1. //Code for the specific URL to open in a new window
  2.   featureLayer.on('click',function(e){
  3.     var specific = e.graphic.attributes['SpecificAttribute']
  4.     window.open("http://YourUrl.com/"+specific);
  5.   });
In the SpecificAttribute, I have placed the name of the field that contains the URLs.
  3.     var specific = e.graphic.attributes['Link']
  4.     window.open(specific);
  5.   });
Any help would be greatly appreciated!
LizEidsness
It is your lucky day - I needed a break from what I was doing, and I learned some things along the way.
If you use this version (combination of the esri sample and your code), you'll notice there's a console.log output of the passport office name on map click. Line 205.  You can handle the rest I think.
A couple problems with your original.  I disabled popups on fLayer.  Consolidated the event handling because you have 3 views.  Complicated!  Also created a click handler!
There is a syntax highlighter in "More... "
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport"
    content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>{PROTOTYPE} Passport Agency Map - JavaScript 4.12</title>
  <!--reference the JavaScript 4.12-->
  <link rel="stylesheet"
    href="https://js.arcgis.com/4.12/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.12/"></script>
  <style>
    html,
    body,
    #mainviewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #hiViewDiv {
      padding: 0;
      margin: 0;
      height: 135px;
      width: 200px;
      background-color: rgba(255, 255, 255, 0.9);
      border-style: solid;
    #prViewDiv {
      padding: 0;
      margin: 0;
      height: 135px;
      width: 200px;
    /*Style for feature hover */
    .esri-feature {
      letter-spacing: 0em;
      line-height: 1.55rem;
      font-feature-settings: "liga"1, "calt"0;
      background: #fff;
      padding: 1em;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/widgets/Home",
      "esri/widgets/BasemapToggle",
      "esri/layers/FeatureLayer",
      "esri/views/MapView",
      "esri/widgets/Feature",
      "esri/widgets/Track",
      "esri/Graphic"
    ], function (Map, Home, BasemapToggle, FeatureLayer, MapView, Feature, Track, Graphic) {
      var fLayer = new FeatureLayer({
        portalItem: {
          id: "5710089ef1374c6d939ebee954c8b15c" //Portal ID number
        popupEnabled: false,
        outFields: ["*"]
      var map = new Map({
        basemap: "streets-navigation-vector",
        layers: [fLayer]
      //Contiguous USA Main Map
      var mainView = new MapView({
        container: "mainviewDiv",
        map: map,
        extent: {
          spatialReference: {
            latestWkid: 3857,
            wkid: 102100
          xmin: -14513000, //bounding box for the inital load of the application
          ymin: 2887000,
          xmax: -7390000,
          ymax: 6326000
        constraints: {
          minScale: 39911104 //user cannot zoom out past this scale
      // Hawaii inset map
      var hiView = new MapView({
        container: "hiViewDiv",
        map: map,
        extent: {
          xmin: -17834000,
          ymin: 2111000,
          xmax: -17173000,
          ymax: 2573000,
          spatialReference: {
            wkid: 102100
        spatialReference: {
          wkid: 102100
        ui: {
          components: []
      mainView.ui.add("hiViewDiv", "bottom-left");
      // Puerto Rico inset map
      var prView = new MapView({
        container: "prViewDiv",
        map: map,
        extent: {
          xmin: -7887000,
          ymin: 1924000,
          xmax: -6957000,
          ymax: 2257000,
          spatialReference: {
            wkid: 102100
        spatialReference: {
          wkid: 102100
        ui: {
          components: []
      mainView.ui.add("prViewDiv", "bottom-right");
      //adding a home button
      var homeBtn = new Home({
        view: mainView
      }); // end of Home Button
      mainView.ui.add(homeBtn, "top-left"); //adding a home button to the top left under the zoom in/out
      var toggle = new BasemapToggle({
        view: mainView,
        nextBasemap: "satellite"
      }); //end of BasemapToggle
      mainView.ui.add(toggle, "top-left"); //adding basemap toggle to the top right
      var graphic = {
        popupTemplate: {
          content: "Mouse over passport icons to show details..."
      // Provide graphic to a new instance of a Feature widget
      var feature = new Feature({
        graphic: graphic,
        map: mainView.map,
        spatialReference: mainView.spatialReference
      mainView.ui.add(feature, "top-right"); //adding feature hover widget to top right
      mainView.when().then(function () {
        // Create a default graphic for when the application starts
        return fLayer.when();
      }).then(function (layer) {
        return mainView.whenLayerView(layer);
      }).then(setupLayerEvent);
      prView
        .when()
        .then(function () {
          return prView.whenLayerView(layer);
      hiView
        .when()
        .then(function () {
          return hiView.whenLayerView(layer);
      function setupLayerEvent(layerView) {
        layerView.view.on("pointer-move", eventHandler);
        layerView.view.on("pointer-down", eventHandler);
        layerView.view.on("click", clickHandler);
        function eventHandler(event) {
          layerView.view.hitTest(event).then(getGraphics);
        function clickHandler(event) {
          layerView.view.hitTest(event).then(function (response) {
            if (response.results.length) {
              const graphic = response.results.filter(function (result) {
                return result.graphic.layer === fLayer;
              })[0].graphic;
              const attributes = graphic.attributes;
              console.log(attributes.Name);  //continue here.
            } else {
        let highlight, currentId;
        function getGraphics(response) {
            })[0].graphic;
            const URL = attributes.Link;
            const id = attributes.FID;
            if (
              highlight && currentId !== id
              highlight.remove();
              highlight = null;
              return;
            // highlight all features belonging to the same hurricane as the feature
            // returned from the hitTest
            const query = layerView.layer.createQuery();
            query.where = "FID = " + id;
            layerView.queryObjectIds(query).then(function (ids) {
              highlight = layerView.highlight(ids);
              feature.graphic = graphic;
              currentId = id;
          } else {
            // remove the highlight if no features are
            highlight.remove();
            highlight = null;
    }); // end of Main function
  </script>
</head>
<body>
  <div id="mainviewDiv" class="esri-widget"></div>
  <div id="hiViewDiv" class="esri-widget"></div>
  <div id="prViewDiv" class="esri-widget"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LizEidsness
Does the event fire? (add console.log entry) or is it the popup itself not working?
MarquesMunson1
The pop-up works and I can access the external website if I click on the icon and then click on the link within the pop-up. I would like to skip the pop-up altogether and when I click on the icon, it goes straight to the external website. I have a feature hover for accessing the info in the pop-up. Hope that helps.
LizEidsness
There's a couple things going on.  Popups need to be disabled on view/layer, or manually handled.  Also FeatureLayer doesn't have a click event.
This sample might help: https://developers.arcgis.com/javascript/latest/sample-code/view-hittest/index.html
In this sample, the view events are handled manually.  It has a lot more going on, but hopefully the event flow can help.
In codepen, after line 139 - I added window.open("http://google.ca");
and on feature click (not mouse over) it opens a window to google.
MarquesMunson1
Here is the code below in full. I am not sure how to copy/paste with the line numbers on the side like in other posts, so sorry if it looks confusing. Would the click event go in the mainView.WhenLayerView function?
<!DOCTYPE html>
<html>
<head>
<meta
name="viewport"
<link rel="stylesheet" href="https://js.arcgis.com/4.12/esri/themes/light/main.css"/>
<style>
html,
body,
#mainviewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#hiViewDiv {
padding: 0;
margin: 0;
height: 135px;
width: 200px;
#prViewDiv{
padding: 0;
margin: 0;
height: 135px;
width: 200px;
.esri-feature {
font-feature-settings: "liga" 1, "calt" 0;
background: #fff;
padding: 1em;
</style>
<script>
require([
"esri/Map",
"esri/Graphic"
], function(Map, Home, BasemapToggle, FeatureLayer, MapView, Feature, Track, Graphic) {
portalItem: {
popupTemplate: {
title: "{Name}",
content: [
type: "fields",
fieldInfos: [
fieldName: "Status"
fieldName: "Address2",
label: "Address"
fieldName: "Link",
label: "Visit Main Page"
fieldName: "Directions",
label: "Get Directions"
var map = new Map({
layers: [fLayer]
map: map,
extent: {
spatialReference: {
latestWkid: 3857,
wkid: 102100
ymin: 2887000,
xmax: -7390000,
ymax: 6326000
constraints: {
// Hawaii inset map
map: map,
extent: {
xmin: -17834000,
ymin: 2111000,
xmax: -17173000,
ymax: 2573000,
spatialReference: {
wkid: 102100
spatialReference: {
wkid: 102100
ui: {
components: []
map: map,
extent: {
xmin: -7887000,
ymin: 1924000,
xmax: -6957000,
ymax: 2257000,
spatialReference: {
wkid: 102100
spatialReference: {
wkid: 102100
ui: {
components: []
view: mainView
var toggle = new BasemapToggle ({
view: mainView,
mainView.when().then(function() {
var graphic = {
popupTemplate: {
graphic: graphic,
map: mainView.map,
mainView.whenLayerView(fLayer).then(function(layerView) {
let highlight;
// listen for the pointer-move event on the View
mainView.on("pointer-move", function(event) {
// Perform a hitTest on the View
mainView.hitTest(event).then(function(event) {
// Make sure graphic has a popupTemplate
let results = event.results.filter(function(result) {
return result.graphic.layer.popupTemplate;
let result = results[0];
highlight && highlight.remove();
// Update the graphic of the Feature widget
// on pointer-move with the result
if (result) {
feature.graphic = result.graphic;
highlight = layerView.highlight(result.graphic);
} else {
///enabling feature hover for Hawaii inset map
hiView.on("pointer-move", function(event) {
hiView.hitTest(event).then(function(event) {
if (result) {
} else {
}); // end hawaii feature hover
///enabling feature hover for puerto rico inset map
prView.on("pointer-move", function(event) {
prView.hitTest(event).then(function(event) {
if (result) {
} else {
}); // end puerto rico feature hover
}); // end of view.when function
</script>
</head>
<body>
</body>
</html>
LizEidsness
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainviewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #hiViewDiv {
      padding: 0;
      margin: 0;
      height: 135px;
      width: 200px;
    #prViewDiv {
      padding: 0;
      margin: 0;
      height: 135px;
      width: 200px;
    .esri-feature {
      background: #fff;
      padding: 1em;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic"
        portalItem: {
        outFields: ["*"]
      var map = new Map({
        layers: [fLayer]
        map: map,
        extent: {
          spatialReference: {
            latestWkid: 3857,
            wkid: 102100
          ymin: 2887000,
          xmax: -7390000,
          ymax: 6326000
        constraints: {
      // Hawaii inset map
        map: map,
        extent: {
          xmin: -17834000,
          ymin: 2111000,
          xmax: -17173000,
          ymax: 2573000,
          spatialReference: {
            wkid: 102100
        spatialReference: {
          wkid: 102100
        ui: {
          components: []
        map: map,
        extent: {
          xmin: -7887000,
          ymin: 1924000,
          xmax: -6957000,
          ymax: 2257000,
          spatialReference: {
            wkid: 102100
        spatialReference: {
          wkid: 102100
        ui: {
          components: []
        view: mainView
        view: mainView,
      var graphic = {
        popupTemplate: {
        graphic: graphic,
        map: mainView.map,
      prView
        .when()
        .then(function () {
      hiView
        .when()
        .then(function () {
              })[0].graphic;
            } else {
            })[0].graphic;
            if (
              highlight.remove();
              highlight = null;
              return;
              currentId = id;
          } else {
            highlight.remove();
            highlight = null;
  </script>
</head>
<body>
</body>
MarquesMunson1
Thank you for helping! I am still trying to figure out the rest. However, now the feature pop-up on the top right does not disappear and is covering up some of the points to  the northeast.
LizEidsness
Glad I could help!
It will always be hard to keep things on top of the map without covering something.  It's also depends on the browser size, or container if this will be in an iframe.
Have fun!
