ArcGIS Server 10.2.2 Cache displaying errors
1987
07-16-2019 12:18 AM
Rutenis
I have a problem with ArcGIS Server 10.2.2 Cache displaying (cache format: Compact, JPEG, 256x259 tile, 96dpi, total levels 12) The problem came unexpectedly, not all of the areas in the Cache are displayed at service, and some areas of the area are not displayed at different scales. The only solution that helps to make things work correctly is to change the Cache location as an example: from C: // ServerCache, to C: // Servercache2. (Deleting a service and rebooting in the same name does not work). ArcGIS Server Clear Cache REST dir also does not help. I add a video to understand my problem more clearly https://streamable.com/ko617.
Maybe somebody has ideas on how to fix it?
Tags (1)
GarimaTiwari
@Ru Bi
Please apply the following patch. This should resolve this issue.
ArcGIS 10.2.2 for Server Map Cache Consumption Patch
Rutenis
thank you Garima Tiwari very much, this update helped solve the problem
