Measurement Widget - Adding multiple location points to map
1896
07-10-2019 11:52 AM
BartPittari
Is there a way to extend the Measurement Widget's Location function to allow for multiple pin locations on a map, and for those pins to be removed individually by the user?  I've got a pin function that I'm using for another part of some code that I'm developing against and, before I try to try and leverage it similarly on this part, I wanted to ask.
I'm using v 3.16 & Dojo for this.
B
RobertScheitlin__GISP
Bart,
   Here is a sample. Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
<!DOCTYPE html>
<html>
<head>
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <title>Measure Tool</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.21/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.21/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #map {
      border: solid 2px #808775;
      -moz-border-radius: 4px;
      -webkit-border-radius: 4px;
      border-radius: 4px;
      margin: 5px;
      padding: 0px;
    #titlePane {
      width: 240px;
    .claro .dijitTitlePaneTitle {
      background: #fff;
      font-weight: 600;
      border: none;
      border-bottom: solid 1px #29201A;
      border-top: solid 1px #29201A;
    .claro .dijitTitlePaneTitleHover {
      background: #eee;
    .claro .dijitTitlePaneTitleActive {
      background: #808775;
    .claro .dijitTitlePaneContentOuter {
      border-right: none;
      border-bottom: none;
      border-left: none;
  </style>
  <script src="http://js.arcgis.com/3.21/"></script>
  <script>
    var map, deleteMGra;
    require([
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "dojo/query",
        "dojo/on",
        "dojo/dom-construct",
        "dojo/_base/array",
        "dojo/dom-style",
        "esri/config",
        "esri/sniff",
        "esri/map",
        "esri/SnappingManager",
        "esri/dijit/Measurement",
        "esri/layers/FeatureLayer",
        "esri/layers/GraphicsLayer",
        "esri/graphic",
        "esri/renderers/SimpleRenderer",
        "esri/tasks/GeometryService",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/PictureMarkerSymbol",
        "esri/dijit/Scalebar",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/TitlePane",
        "dijit/form/CheckBox",
        "dojo/domReady!"
      ], function (
      dom, Color, keys, parser, query, on, domConstruct, array, domStyle,
      esriConfig, has, Map, SnappingManager, Measurement, FeatureLayer, GraphicsLayer, Graphic,
      SimpleRenderer, GeometryService, SimpleLineSymbol, SimpleFillSymbol, PictureMarkerSymbol
      parser.parse();
      //This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to
      //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
      //for details on setting up a proxy page.
      esriConfig.defaults.io.proxyUrl = "/proxy/";
      esriConfig.defaults.io.alwaysUseProxy = false;
      //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
      esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
      map = new Map("map", {
        basemap: "satellite",
        center: [-85.743, 38.256],
        zoom: 17
      var sfs = new SimpleFillSymbol(
        "solid",
        new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
        null
      var parcelsLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["*"]
      parcelsLayer.setRenderer(new SimpleRenderer(sfs));
      map.addLayers([parcelsLayer]);
      //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
      var snapManager = map.enableSnapping({
        snapKey: has("mac") ? keys.META : keys.CTRL
      var layerInfos = [{
        layer: parcelsLayer
      snapManager.setLayerInfos(layerInfos);
      var measureGL = new GraphicsLayer();
      var pms = new PictureMarkerSymbol('http://js.arcgis.com/3.21/esri/dijit/images/esriGreenPin16x26.png', 16, 26);
      pms.setOffset(0, 12);
      map.addLayers([measureGL]);
      var measurement = new Measurement({
        map: map,
      }, dom.byId("measurementDiv"));
      measurement.startup();
      measurement.on("tool-change", function (evt) {
        if (evt.toolName !== "location") {
          //If a tool other than the location tool or the location tool has been toggled off
          //Clear the graphics layer
          measureGL.clear();
          //Remove all the rows of locations added by the code
          var rows = query(".myMeasurementTableRow");
          array.forEach(rows, function (row) {
            domConstruct.destroy(row);
          //Hide the Graphics Layer
          measureGL.hide();
        } else {
          measureGL.show();
          //show the standard location measure row that was hidden
          var mRows = query(".esriMeasurementTableRow");
          domStyle.set(mRows[1], "display", "");
      measurement.on("measure", function (evt) {
        switch (evt.toolName) {
        case "location":
          break;
        default:
          var resultDiv = query(".dijitContentPane .esriMeasurementResultValue")[0];
          console.info(measurement);
          var result = domConstruct.toDom("<div class='result'>" + evt.values[0] + "<div>");
          domConstruct.place(resultDiv, result);
          break;
      deleteMGra = function (){
        var rowId = this.event.target.id;
        domConstruct.destroy(this.event.target.id);
        //loop trough the graphics and delete this graphic by ID
        measureGL.graphics.some(function(g){
          if(g.attributes.Id === rowId){
            measureGL.remove(g);
            if(measureGL.graphics.length == 0){
              measurement.clearResult();
            return true;
      measurement.on("measure-end", function (evt) {
        case "location":
          //console.log("Lat: " + evt.values[0] + " Lng: " + evt.values[1]);
          var tbl = query(".esriMeasurementResultTable tbody")[0];
          var eRows = query(".esriMeasurementTableRow");
          var mRows = query(".myMeasurementTableRow");
          var rowId = "mrowid" + (mRows.length + 1 ).toString();
          var row = domConstruct.toDom("<tr class='myMeasurementTableRow' id='" + rowId + "'>" +
            "<td><img src='http://js.arcgis.com/3.14/esri/dijit/images/esriGreenPin16x26.png' style='vertical-align:middle'></td>" +
            "<td class='esriMeasurementTableCell'>" + evt.values[0] + "</td><td class='esriMeasurementTableCell'>" + evt.values[1] +
            "</td><td><span style='cursor:pointer;color:red;font-weight:bold;padding:0 2px;' id='" + rowId + "'" +
            " onClick='deleteMGra()'>X</span></td></tr>");
          //Hide the standard measure loaction row so that there is not two identical measures
          domStyle.set(eRows[1], "display", "none");
          domConstruct.place(row, tbl);
          //Add the measure to the Graphics Layer
          measureGL.add(new Graphic(evt.geometry, pms, {
            "Lat": evt.values[0],
            "Lon": evt.values[1],
            "Id": rowId
          measurement._measureGraphics[0]._graphicsLayer.clear();
          break;
        default:
          var resultDiv = query(".esriMeasurementResultValue")[0];
          break;
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
          <div id="measurementDiv"></div>
          <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Bart,
   Something like this? You can place multiple points on the map and right click a point to delete it.
<!DOCTYPE html>
<html>
  <head>
    <link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/themes/calcite/dijit/calcite.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/themes/calcite/esri/esri.css">
    <style>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #map {
        border:solid 2px #808775;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:280px;
      </style>
      <script src="https://js.arcgis.com/3.29/"></script>
    <script>
    var map;
    require([
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "esri/config",
        "esri/sniff",
        "esri/map",
        "esri/graphic",
        "dijit/Menu", "dijit/MenuItem", "dijit/MenuSeparator",
        "dijit/TitlePane",
        "dojo/domReady!"
      ], function(
        esriConfig, has, Map, SnappingManager, Measurement, FeatureLayer, SimpleRenderer, GeometryService, SimpleLineSymbol, SimpleFillSymbol, GraphicsLayer, Graphic,
          Menu, MenuItem, MenuSeparator
        parser.parse();
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
          zoom: 17
        var mGL = new GraphicsLayer();
        map.on("load", createGraphicsMenu);
        function createGraphicsMenu() {
          map.addLayer(mGL);
          // Creates right-click context menu for GRAPHICS
          ctxMenuForGraphics = new Menu({});
          ctxMenuForGraphics.addChild(new MenuItem({
            label: "Delete",
            onClick: function() {
              mGL.remove(selected);
          ctxMenuForGraphics.startup();
          mGL.on("mouse-over", function(evt) {
            // We'll use this "selected" graphic to enable editing tools
            // on this graphic when the user click on one of the tools
            // listed in the menu.
            selected = evt.graphic;
            // Let's bind to the graphic underneath the mouse cursor
            ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
          mGL.on("mouse-out", function(evt) {
            ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
          "solid",
          null
        var parcelsLayer = new FeatureLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
          outFields: ["*"]
        var layerInfos = [{
          layer: parcelsLayer
          map: map
        measurement.on('measure-end', function(evt){
          var geom = evt.geometry;
          var gra = new Graphic(geom, measurement._pointSymbol)
          mGL.add(gra);
    </script>
  </head>
  <body class="calcite">
          <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:false">
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
BartPittari
Robert,
That's along the lines of what I was trying to do.  I'm needing to add the points to a list which I was going to put below where the green pin marker was located.  From there, they would have the option to remove individual ones or clear the list.
Bart
Yet totally possible.
Bart,
<!DOCTYPE html>
<html>
<head>
    on iOS devices-->
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
    body {
      overflow: hidden;
    #map {
      border-radius: 4px;
      margin: 5px;
      padding: 0px;
    #titlePane {
      width: 240px;
      background: #fff;
      font-weight: 600;
      border: none;
      background: #eee;
      border-right: none;
      border-left: none;
  </style>
  <script>
    require([
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "dojo/query",
        "dojo/on",
        "dojo/_base/array",
        "dojo/dom-style",
        "esri/config",
        "esri/sniff",
        "esri/map",
        "esri/graphic",
        "dijit/TitlePane",
        "dojo/domReady!"
      ], function (
      parser.parse();
        zoom: 17
        "solid",
        null
        outFields: ["*"]
      var layerInfos = [{
        layer: parcelsLayer
        map: map,
          measureGL.clear();
          measureGL.hide();
        } else {
          measureGL.show();
        case "location":
          break;
        default:
          break;
            return true;
        case "location":
            "Id": rowId
          break;
        default:
          break;
  </script>
</head>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
