Access violation when routing with offline map
2430
07-10-2019 05:45 AM
RobrechtUlens
When creating MapPoints to define stops for a route, I was under the impression that these would accept longitude and latitude coordinates. I tried to calculate a route using these coordinates and my application had a hard crash due to an access violation.
I figured out that I could convert from longitude latitude to mappoints using CoordinateFormatter.FromLatitudeLongitude(). This has solved my issue. I guess before it was trying to route between points that were not in the offline map package I was using.
I thought I would let you know about this hard crash. Attached is a project that reproduces the issue. I am using 100.5.0 of the .NET SDK and I'm using the belgium.mmpk map which I downloaded from https://developers.arcgis.com/downloads/streetmap-premium-for-runtime. I also tried the 100.4.0 .NET SDK and got the same problem.
Kind regards,
Robrecht
RobrechtUlens
Hi Michael Branscomb
The issue is no longer reproducible with version 100.6.0 of the SDK.
Robrecht
MichaelBranscomb
Esri Frequent Contributor
Thanks for the straightforward repro case. I've open an issue in our backlog and we'll investigate.
Cheers
Mike
MichaelBranscomb
This issue requires further investigation to determine the cause of the error and the appropriate resolution.
In the interim you can workaround this by specifying the SpatialReference of the Stop geometries you are creating:
e.g.
`List<MapPoint> coordinates = new List<MapPoint> { new MapPoint(50.9208595, 5.3386841,SpatialReferences.Wgs84), new MapPoint(50.9299484, 5.3944303,SpatialReferences.Wgs84) };`
These specific coordinates will cause the SolveRouteAsync task to return an exception that you can catch. The exception message indicates that the Stops cannot be located on the network.
Cheers
Mike
RobrechtUlens
Robrecht
MichaelBranscomb
Thanks for confirming.
Cheers
Mike
