Reset Questions When Editing Through Inbox
610
07-08-2019 10:17 AM
JoshHabel
Does anyone know if it is possible to reset or re-ask a question automatically when you go to edit through inbox.  What i'm trying to do is create a way that a manager could edit fields in a previously sent survey that would normally be read only to a user.  I have tried using the following function in the read only column ${username}!='manager_username' however it seems that when the survey is initially sent that the username field gets populated by the original user but does not reset for the editor.  Is there anyway around this issue to achieve what i've trying to do?
Josh
Shwu-jingJeng
Hi Josh,
Please see this post regarding the similar issue with username type questions.
https://community.esri.com/thread/226878-survey123-username-field-is-null
You are probably running into BUG-000113164, which the value won't be updated again after the survey is submitted.
