Import metadata template to raster dataset in Pro using python?
2064
07-01-2019 01:36 PM
by Anonymous User
Not applicable
I have 328 raster datasets in my GDB I will be publishing to Portal as an image service. I have a metadata template I want to import for each of these rasters. Is there a way to do this with python? I found that ArcMap had an ImportMetadata_conversion tool that could've worked (I think?) but Pro does not have it. Just updated to Pro 2.4. Thank you!
Tags (5)
DanPatterson_Retired
by Anonymous User
Not applicable
Thanks for the reply Dan. Do you know of a way to fill in the metadata (item details) when publishing instead? Maybe there's hope going that direction.
Sorry Bryan, perhaps with the 'arcgis'  module in the api reference.
API Reference for the ArcGIS API for Python — arcgis 1.6.2 documentation
by Anonymous User
Not applicable
I looked through the documentation with my co-worker who is far more advanced in python and ArcGIS API for Python than me and the documentation indicated there is a 'metadata' property for the Map Image Layer Manager (arcgis.mapping.MapImageLayerManager.metadata), but we couldn't find any documentation for it.
