C# QueryFilter prefixClause "DISTINCT" non-functional
2701
07-01-2019 07:50 AM
MikeRatcliffe
I'm finding that QueryFilter prefixClause "DISTINCT" is non-functional in the SDK and must use a workaround:
                QueryFilter filter = new QueryFilter
                    //PrefixClause = "DISTINCT",              //DISTINCT does not work in this query. See workaround below.
                    SubFields = "FY",
                    WhereClause = "FY IS NOT NULL AND FY <> '-9' AND FY <> ' '",
                    PostfixClause = "ORDER BY FY"
                using (RowCursor rowCursor = sso_lyr.Search(filter))
                    int fldIndex = rowCursor.FindField("FY");
                    List<string> valuelist = new List<string>();
                    while (rowCursor.MoveNext())
                        string value = rowCursor.Current.GetOriginalValue(fldIndex) as string;
                        valuelist.Add(value);
                    IEnumerable<string> distinctvaluelist = valuelist.Select(x => x).Distinct(); //distinct from list b/c DISTINCT prefixclause non-functional above.
                    foreach (string item in distinctvaluelist)
                        Invoke(new MethodInvoker(delegate { Sso_combo.Items.Add(item); }));
This is okay for very short lists of values, but not for 100,000 records; which is the requirement.
Has anyone else encountered this?  I'm using documentation from this source:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Geodatabase
Word find: "distinct" on the page...
RichRuh
Shape files do not support the Distinct clause.
To see what clauses are supported by a particular datastore, you can call Datastore.GetSQLSyntax().  This method returns a SQLSyntax object.  SQLSyntax.GetSupportedClauses() returns a list of the supported clauses.
I'll update the conceptual doc to make this more clear.
--Rich
RichRuh
Hi Mike,
What kind of database are you trying to run this against?
--Rich
MikeRatcliffe
Hey, Rich.
it is a FeatureLayer with the source of SSO_Events.shp > SSO_Events.lyr.
RichRuh
--Rich
MikeRatcliffe
Thanks, Rich.
