I'm finding that QueryFilter prefixClause "DISTINCT" is non-functional in the SDK and must use a workaround:
QueryFilter filter = new QueryFilter
//PrefixClause = "DISTINCT", //DISTINCT does not work in this query. See workaround below.
SubFields = "FY",
WhereClause = "FY IS NOT NULL AND FY <> '-9' AND FY <> ' '",
PostfixClause = "ORDER BY FY"
using (RowCursor rowCursor = sso_lyr.Search(filter))
int fldIndex = rowCursor.FindField("FY");
List<string> valuelist = new List<string>();
while (rowCursor.MoveNext())
string value = rowCursor.Current.GetOriginalValue(fldIndex) as string;
valuelist.Add(value);
IEnumerable<string> distinctvaluelist = valuelist.Select(x => x).Distinct(); //distinct from list b/c DISTINCT prefixclause non-functional above.
foreach (string item in distinctvaluelist)
Invoke(new MethodInvoker(delegate { Sso_combo.Items.Add(item); }));
This is okay for very short lists of values, but not for 100,000 records; which is the requirement.
Has anyone else encountered this? I'm using documentation from this source:
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Geodatabase
Word find: "distinct" on the page...
Solved! Go to Solution.
Shape files do not support the Distinct clause.
To see what clauses are supported by a particular datastore, you can call Datastore.GetSQLSyntax(). This method returns a SQLSyntax object. SQLSyntax.GetSupportedClauses() returns a list of the supported clauses.
I'll update the conceptual doc to make this more clear.
--Rich
Hi Mike,
What kind of database are you trying to run this against?
--Rich
Hey, Rich.
it is a FeatureLayer with the source of SSO_Events.shp > SSO_Events.lyr.
--Rich
