ArcGIS Online X,y
272
06-27-2019 06:58 AM
JordanHolt
Good Morning,
 I have published a service with roughly 180,000 points. I am trying to connect Survey123 with a Web Map using the configure pop-up. I want to transfer data from the "master" database to the survey so the user in the field doesn't have to type all that information. It seems to be working for all fields but I noticed when it draws the point created off survey123 (center:{Y},{X}) its off set. I looked back at my "master" database and its only showing the X and Y with 2 decimals (-94.51). Why would my feature service only be showing 2 decimal places? This is causing my survey123 to pick up the incorrect data and draw the point offset from the original data. Anyone else have this problem or have the solution?
Thanks!!
