Select Widget Issue
564
06-26-2019 10:33 AM
BrianLeroux
I am using WebAppBuilder Dev 2.11 to build my app. When using the select tool I notice it does not accurately select points from my dynamic map service. My service contains hunderds of thousands of points across the US. As you can see in the attached video there is one point that does not want to be selected unless selected that record alone. Any ideas on the cause or how to troubleshoot?
BrianLeroux
Additional info: Using the query widget draw function I get the correct number of reults back when drawing a box. Doing the exact same box with the select tool gives me an incorrect number of results.
