Is it possible to use vector base maps in Portal for ArcGIS?
5556
16
06-20-2019 02:04 PM
ChristopherBates
I've been testing the functionality  of the ArcGIS Vector Tile Style Editor described in this ArcGIS Blog Post: https://www.esri.com/arcgis-blog/products/developers/mapping/design-custom-basemaps-with-the-new-arc...
I'm wondering it is possible to consume the customs basemap in my organization's portal? I have a web map hosted in Portal that could really use a custom basemap.
Anyone have any success with this?
Thanks!
ChelseaRozek
MVP Regular Contributor
   I was able to customize an ESRI light grey vector basemap in our Portal with help from this story map: https://www.arcgis.com/apps/Cascade/index.html?appid=a74a8b251f6141fa9561041d36ea56e3
   I created a quick style with the Vector Style Editor and downloaded it as a json. In Portal, I added an ESRI vector basemap to a webmap (NOT as a basemap, just as a normal layer; Living Atlas content needs to be configured in Portal), copied it as a layer in the TOC, then on that new copy, clicked the 3 dot menu, clicked on Save Layer. On that new saved item in Portal, on its item details page, you can Update style with the json you exported from the Style Editor.
ChelseaRozek
ChristopherBates
Awesome! Thank you for the reply Chelsea, I followed your steps and it seems to be working (although there were a nervous few minutes where nothing was loading in my Web Map in Portal).
Cheers!
Chris
ChristopherBates
Hello again. I have a follow up question. I was able to create great looking custom vector tile basemap and it looks great in ArcGIS Online - but if I follow the above steps and apply the .json to a Vector Tile Basemap in Portal, i'm encountering rendering issues (it won't redraw as I zoom in). Have you encountered this? I'm wondering if it has something to do with the version of portal i'm using.
Thanks!
ChelseaRozek
Which version of Portal are you on? We're on 10.7. Can you upload a copy of the .json? I haven't used a custom vector tile basemap in production yet, so I haven't had a chance to run into any issues.
ChristopherBates
I'm on version 10.5.1  I can't seem to attach the source code here - but I sent one via email.
ChelseaRozek
Did you send it to my work email? I haven't received anything yet. Our spam filters may have been a little overzealous. Could you try zipping it or sending it as a .txt file?
ChristopherBates
Sorry about that. I've attached the .json file. Thanks again.
ChelseaRozek
Nice classic look! It seems to be visualizing fine for me in the Portal Map Viewer. Draws at a reasonable speed when zooming. Do you see a difference in drawing between the map viewer and an application? Would you be able to upgrade Portal?
ChristopherBates
That's good to hear. Can i ask what version of Portal you are using? It may be possible for me tot upgrade.
For reference, this is what it currently looks like when I try to view it in Portal Viewer:
