I've been testing the functionality of the ArcGIS Vector Tile Style Editor described in this ArcGIS Blog Post: https://www.esri.com/arcgis-blog/products/developers/mapping/design-custom-basemaps-with-the-new-arcgis-vector-tile-style-editor/
I'm wondering it is possible to consume the customs basemap in my organization's portal? I have a web map hosted in Portal that could really use a custom basemap.
Anyone have any success with this?
Thanks!
I was able to customize an ESRI light grey vector basemap in our Portal with help from this story map: https://www.arcgis.com/apps/Cascade/index.html?appid=a74a8b251f6141fa9561041d36ea56e3
I created a quick style with the Vector Style Editor and downloaded it as a json. In Portal, I added an ESRI vector basemap to a webmap (NOT as a basemap, just as a normal layer; Living Atlas content needs to be configured in Portal), copied it as a layer in the TOC, then on that new copy, clicked the 3 dot menu, clicked on Save Layer. On that new saved item in Portal, on its item details page, you can Update style with the json you exported from the Style Editor.
Awesome! Thank you for the reply Chelsea, I followed your steps and it seems to be working (although there were a nervous few minutes where nothing was loading in my Web Map in Portal).
Cheers!
Chris
Hello again. I have a follow up question. I was able to create great looking custom vector tile basemap and it looks great in ArcGIS Online - but if I follow the above steps and apply the .json to a Vector Tile Basemap in Portal, i'm encountering rendering issues (it won't redraw as I zoom in). Have you encountered this? I'm wondering if it has something to do with the version of portal i'm using.
Which version of Portal are you on? We're on 10.7. Can you upload a copy of the .json? I haven't used a custom vector tile basemap in production yet, so I haven't had a chance to run into any issues.
I'm on version 10.5.1 I can't seem to attach the source code here - but I sent one via email.
Did you send it to my work email? I haven't received anything yet. Our spam filters may have been a little overzealous. Could you try zipping it or sending it as a .txt file?
Sorry about that. I've attached the .json file. Thanks again.
We too had a difficult time with modified vector tile display in our ArcGIS Online org when it was at the 10.5.x equivalent, so much so that I left it alone for some time.
We have since moved fully to the Enterprise and are at 10.7.1 and the workflows mentioned here do work and we now have a modified style of the Light Gray Reference layer (although not the new WGS84 style) that I can use as reference layer on top of my own vector tile base layers. It works well in the portal map viewer and in Web Application Builder's (2.13) basemap gallery widget.
HOWEVER, the modified Light Gray Reference layer (that I am calling our Local Gray Canvas Reference layer) will not load as a layer into ArcGIS Pro at 2.4.2 without error. Not sure why. In my portal, the modified vector tile shows as coming from my https://myorg.net/portal/sharing/rest/content/... directory, but the source url of the modified tile layer still shows as coming from the esri source at https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer
Don't have a workaround yet. It kinda feels like a CORS issue.
Perfect! Thanks
This has since become a non-issue with the vector tile style editor available at 10.8
Signed in members can post, follow updates, and more. New here? Register a free account.
