RuntimeError: ERROR 999998: Unexpected Error in Set null function
12267
35
06-19-2019 05:53 AM
BIJOYGAYEN
I am trying to write one code where I use set null function for different images and also use a simple math function for scaling the images. But when I run this code after three processes it shows
  File "F:\DB_test_data\python_script\FINAL_DB.py", line 192, in <module>
    arcpy.CopyRaster_management(toa_b2,OutRaster)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.6\ArcPy\arcpy\management.py", line 14587, in CopyRaster
    raise e
RuntimeError: ERROR 999998: Unexpected Error.‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
here is my code
outdir="F:\\DB_test_data\\TEST_RAY\\TEST1\\c\\"
for a,b,c,d,e,f,g,h,i,j,k,l in zip (CLDMASK,AOD,TOA_B1,TOA_B2,Height,SenZen,SenAzm,SolZen,SolAzm,Sur_B1,Sur_B2,Sur_B3):
    print ("processing_a:"+ a)
    print ("processing_b:"+ b)
    print ("processing_c:"+ c)
    print ("processing_d:"+ d)
    print ("processing_e:"+ e)
    print ("processing_f:"+ f)
    print ("processing_g:"+ g)
    print ("processing_h:"+ h)
    print ("processing_i:"+ i)
    print ("processing_j:"+ j)
    print ("processing_k:"+ k)
    print ("processing_l:"+ l)
    #Cloud Mask scalling
    Scale_factor1 = float(1.0)
    add_offset1 = float(0.0)
    setnull1 =arcpy.gp.SetNull_sa(a,a, "in_memory/dat1", "\"Value\" <= 0")
    ras1=arcpy.Raster(setnull1)
    cldmask=(ras1-add_offset1)*Scale_factor1
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("cldmask"))
    #print OutRaster
    arcpy.CopyRaster_management(cldmask,OutRaster)
    arcpy.Delete_management("in_memory/dat1")
    #AOD scalling and set lessthan 0.1 AOD
    Scale_factor2 = float(0.0010000000474974513)
    add_offset2 = float(0.0)
    setnull2 =arcpy.gp.SetNull_sa(b,b, "in_memory/dat2", "\"Value\" = -9999")
    ras2=arcpy.Raster(setnull2)
    aod=(ras2-add_offset2)*Scale_factor2
    aod_1 = Con((aod >= 0.0) & (aod <= 0.1),1)
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("aod_1"))
    #print OutRaster
    arcpy.CopyRaster_management(aod_1,OutRaster)
    arcpy.Delete_management("in_memory/dat2")
    #TOA_B1 scalling
    Scale_factor3 = float(0.000053811826)
    add_offset3 = float(-0.0)
    setnull3 =arcpy.gp.SetNull_sa(c,c, "in_memory/dat3", "\"Value\" = 65535")
    ras3=arcpy.Raster(setnull3)
    toa_b1=(ras3-(add_offset3))*Scale_factor3
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("toa_b1"))
    #print OutRaster
    arcpy.CopyRaster_management(toa_b1,OutRaster)
    arcpy.Delete_management("in_memory/dat3")
    #TOA_B2 Scalling
    Scale_factor4 = float(0.00003255546)
    add_offset4 = float(-0.0)
    setnull4 =arcpy.gp.SetNull_sa(d,d, "in_memory/dat4", "\"Value\" = 65535")
    ras4=arcpy.Raster(setnull4)
    toa_b2=(ras4-(add_offset4))*Scale_factor4
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("toa_b2"))
    #print OutRaster
    arcpy.Delete_management("in_memory/dat4")
    #Height
    setnull =arcpy.gp.SetNull_sa(e,e, "in_memory/dat5", "\"Value\" = -32767")
    ras=arcpy.Raster(setnull)
    height=ras
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("height"))
    #print OutRaster
    arcpy.CopyRaster_management(height,OutRaster)
    arcpy.Delete_management("in_memory/dat5")
    #Sensor Zenith angle
    Scale_factor6 = float(0.01)
    add_offset6 = float(0.0)
    setnull6 =arcpy.gp.SetNull_sa(f,f, "in_memory/dat6", "\"Value\" = -32767")
    ras6=arcpy.Raster(setnull6)
    senzen=(ras6-add_offset6)*Scale_factor6
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("senzen"))
    #print OutRaster
    arcpy.CopyRaster_management(senzen,OutRaster)
    arcpy.Delete_management("in_memory/dat6")
    #Sensor azimuth angle
    setnull7 =arcpy.gp.SetNull_sa(g,g, "in_memory/dat7", "\"Value\" = -32767")
    ras7=arcpy.Raster(setnull7)
    senazm=(ras7-add_offset6)*Scale_factor6
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("senazm"))
    #print OutRaster
    arcpy.CopyRaster_management(senazm,OutRaster)
    arcpy.Delete_management("in_memory/dat7")
    #solar zenithal angle
    setnull8 =arcpy.gp.SetNull_sa(h,h, "in_memory/dat8", "\"Value\" = -32767")
    ras8=arcpy.Raster(setnull8)
    solzen=(ras8-add_offset6)*Scale_factor6
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("solzen"))
    #print OutRaster
    arcpy.CopyRaster_management(solzen,OutRaster)
    arcpy.Delete_management("in_memory/dat8")
    #solar azimuth angle
    setnull9 =arcpy.gp.SetNull_sa(i,i, "in_memory/dat9", "\"Value\" = -32767")
    ras9=arcpy.Raster(setnull9)
    solazm=(ras9-add_offset6)*Scale_factor6
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("solazm"))
    #print OutRaster
    arcpy.CopyRaster_management(solazm,OutRaster)
    arcpy.Delete_management("in_memory/dat9")
    #(MODO9)surface reflectance band 1
    Scale_factor_10 = float(0.0001)
    add_offset_10 = float(0.0)
    setnull_10 =arcpy.gp.SetNull_sa(j,j, "in_memory/dat10", "\"Value\" = -28672")
    ras_10=arcpy.Raster(setnull_10)
    sur_b1=(ras_10-add_offset_10)*Scale_factor_10
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("sur_b1"))
    #print OutRaster
    arcpy.CopyRaster_management(sur_b1,OutRaster)
    arcpy.Delete_management("in_memory/dat10")
    #(MODO9)surface reflectance band 2
    setnull_11 =arcpy.gp.SetNull_sa(k,k, "in_memory/dat11", "\"Value\" = -28672")
    ras_11=arcpy.Raster(setnull_11)
    sur_b2=(ras_11-add_offset_10)*Scale_factor_10
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("sur_b2"))
    #print OutRaster
    arcpy.CopyRaster_management(sur_b2,OutRaster)
    arcpy.Delete_management("in_memory/dat11")
    #(MODO9)surface reflectance band 3
    setnull_12 =arcpy.gp.SetNull_sa(l,l, "in_memory/dat12", "\"Value\" = -28672")
    ras_12=arcpy.Raster(setnull_12)
    sur_b3=(ras_12- add_offset_10)*Scale_factor_10
    OutRaster = os.path.join(outdir,'MOd0.{0}.img'.format("sur_b3"))
    #print OutRaster
    arcpy.CopyRaster_management(sur_b3,OutRaster)
    arcpy.Delete_management("in_memory/dat12")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
    # # Process: Extract by Cloud_Mask
    # tempEnvironment0 = arcpy.env.cellSize
    # arcpy.env.cellSize = "MAXOF"
    # toa_bb1=arcpy.gp.ExtractByMask_sa(toa_b1, cldmask)
    # toa_b22=arcpy.gp.ExtractByMask_sa(toa_b2, cldmask)
    # heightt=arcpy.gp.ExtractByMask_sa(height, cldmask)
    # senzenn=arcpy.gp.ExtractByMask_sa(senzen, cldmask)
    # senazmm=arcpy.gp.ExtractByMask_sa(senazm, cldmask)
    # solzenn=arcpy.gp.ExtractByMask_sa(solzen, cldmask)
    # solazmm=arcpy.gp.ExtractByMask_sa(solazm, cldmask)
    # sur_b11=arcpy.gp.ExtractByMask_sa(sur_b1, cldmask)
    # sur_b22=arcpy.gp.ExtractByMask_sa(sur_b2, cldmask)
    # sur_b33=arcpy.gp.ExtractByMask_sa(sur_b3, cldmask)
    # arcpy.env.cellSize = tempEnvironment0
    # # Process: Extract by Mask using AOD less than 0.1 value
    # arcpy.env.cellSize = cellsize
    # toa_b1=arcpy.gp.ExtractByMask_sa(toa_bb1, aod_1)
    # toa_b2=arcpy.gp.ExtractByMask_sa(toa_bb2, aod_1)
    # height=arcpy.gp.ExtractByMask_sa(heightt, aod_1)
    # senzen=arcpy.gp.ExtractByMask_sa(senzenn, aod_1)
    # senazm=arcpy.gp.ExtractByMask_sa(senazmm, aod_1)
    # solzen=arcpy.gp.ExtractByMask_sa(solzenn, aod_1)
    # solazm=arcpy.gp.ExtractByMask_sa(solazmm, aod_1)
    # sur_b1=arcpy.gp.ExtractByMask_sa(sur_b11, aod_1)
    # sur_b2=arcpy.gp.ExtractByMask_sa(sur_b22, aod_1)
    # sur_b3=arcpy.gp.ExtractByMask_sa(sur_b33, aod_1)
    #Calculate the scattering angle from Resample MOD03 products
      #Css = Cos(S2 * !pi / 180.D) IDL
      #Css = np.cos(S2 * np.pi / 180) Python
    # CosSenZ = np.Cos(senzen * np.pi / 180)
    # CosSolZ = np.Cos(solzen * np.pi / 180)
    # SinSenZ = np.Sin(senzen * np.pi / 180)
    # SinSolZ = np.Sin(solzen * np.pi / 180)
    # RelAzm = np.abs((senazm ) - (solazm))
    # index = np.where(RelAzm > 180.0)
    # RelAzm[index] = 360.0- RelAzm[index]
    # index = np.where(RelAzm <= 180.0)
    # RelAzm[index] = 180.0- RelAzm[index]
    # CosRe = np.Cos(np.radians(RelAzm))
    # SctAgl =  np.acos((-CosSolZ * CosSenZ) + ((SinSolZ * SinSenZ) * CosRelA))
    # #Ray_correction for TOA_BAND_1 and TOA_BAND_2
    # #TOA_BAND_1
    # B1_ROD = (0.00864 + (0.0000065)) * (0.67)**(-(3.916 + (0.074 * 0.67)+ (0.05/0.67)))#for RED band, please change 0.67 for other bands wavelength
    # Pr1 =  (3./16.*np.pi) * (1 + (np.cos(SctAgl) * np.cos(SctAgl)))
    # wr1 = 1.0
    # RayRef_B1 = (wr1 * B1_ROD * Pr1 ) / (4.0 * (CosSolZ * CosSenZ))
    # RCR_B1 = toa_b1 - RayRef_B1
    # #TOA_BAND_2
    # B2_ROD = (0.00864 + (0.0000065)) * (0.86)**(-(3.916 + (0.074 * 0.86)+ (0.05/0.86)))#for Near Infrared (NIR) band, please change 0.86 for other bands wavelength
    # Pr2 =  (3./16.*np.pi) * (1 + (np.cos(SctAgl) * np.cos(SctAgl)))
    # wr2 = 1.0
    # RayRef_B2 = (wr2 * B2_ROD * Pr2 ) / (4.0 * (CosSolZ * CosSenZ))
    # RCR_B2 = toa_b2 - RayRef_B2
    #Calculating NDVI float raster
    # ndvi_raster = Divide(Float(Raster(toa_b2) - Raster(toa_b1)), Float(Raster(toa_b2) + Raster(toa_b1)))
    # ndvi = (Float(toa_b2) - toa_b1) / (Float(toa_b2) + toa_b1)
print arcpy.GetMessages()
print 'finished run: %s\n\n' % (datetime.datetime.now() - start)
I can't understand why it shows this error.
please help me, anyone, to resolve this matter.
And have any way to use a "foor loop" for set null function of different images?
Xander Bakker
Luke Webb‌,
Joshua Bixby
Joe Borgione
Dan Patterson
JoeBorgione
The error is stating a problem on line 192, but the code you provide only goes to 136: can't help you there.
This stack exchange thread mentions background processing which you asked about in an earlier post:  https://gis.stackexchange.com/questions/27190/error-999998-unexpected-error  (Dr Google is a good friend when it comes to error codes...)
BIJOYGAYEN
Sorry for there some missing line, again I uploading my full code. Please check this issue...
Even I did not find any solution according to my problem
# Name:        module1
# Purpose:
# Author:      HONEY
# Created:     18-06-2019
# Copyright:   (c) HONEY 2019
# Licence:     <your licence>
import datetime
start = datetime.datetime.now()
print 'start run: %s\n' % (start)
import arcpy ,os ,sys,csv,errno
from arcpy import env
from arcpy.sa import *
import datetime
import re
import numpy as np
import glob
import itertools
cellsize = "F:\\DB_test_data\\TEST_RAY\\TEST1\\MOD02HKM_A2017001_0530_NDVI_AA.img"
#Call cloud mask images from directory
d1="F:\\DB_test_data\\VAR2\\cldmask\\"
CLDMASK = glob.glob(d1 + os.sep + "*.Aerosol_Cldmask_Land_Ocean-Aerosol_Cldmask_Land_Ocean.tif")
CLDMASK.sort()
if CLDMASK is None:
    print 'Could not open the CLDMASK raster files'
    sys.exit(1)
else:
    print 'The CLDMASK raster files was opened successfully'
#Call AOD images from directory
d2 = r"F:\\DB_test_data\\VAR2\\MOD04_l2"
AOD = glob.glob(d2 + os.sep + "*Corrected_Optical_Depth_Land_2-Corrected_Optical_Depth_Land.tif")
AOD.sort()
if AOD is None:
    print 'Could not open the AOD raster files'
    sys.exit(1)
else:
    print 'The AOD raster files was opened successfully'
#Call MOD02HKM_TOA-B1_TOA-B2 images from directory
d3="F:\\DB_test_data\\VAR2\\IDL\\MOD02HKM\\"
TOA_B1 = glob.glob(d3 + os.sep + "*RefSB_1-EV_250_Aggr500_RefSB.tif")
TOA_B1.sort()
if TOA_B1 is None:
    print 'Could not open the TOA_B1 raster files'
    sys.exit(1)
else:
    print 'The TOA_B1 raster files was opened successfully'
TOA_B2 = glob.glob(d3 + os.sep + "*RefSB_2-EV_250_Aggr500_RefSB.tif")
TOA_B2.sort()
if TOA_B2 is None:
    print 'Could not open the TOA_B2 raster files'
    sys.exit(1)
else:
    print 'The TOA_B2 raster files was opened successfully'
#Call MOD03  (Height,SenZen,SenAzm,SolZen,SolAzm) images from directory
d4="F:\\DB_test_data\\VAR2\\IDL\\MOD03_R\\"
Height = glob.glob(d4 + os.sep + "*.Height-Height.tif")
Height.sort()
if Height is None:
    print 'Could not open the  Height raster files'
    sys.exit(1)
else:
    print 'The Height raster files was opened successfully'
SenZen = glob.glob(d4 + os.sep + "*.SensorZenith-SensorZenith.tif")
SenZen.sort()
if SenZen is None:
    print 'Could not open the SenZen raster files'
    sys.exit(1)
else:
    print 'The SenZen raster files was opened successfully'
SenAzm = glob.glob(d4 + os.sep + "*.SensorAzimuth-SensorAzimuth.tif")
SenAzm.sort()
if SenAzm is None:
    print 'Could not open the  SenAzm raster files'
    sys.exit(1)
else:
    print 'The SenAzm raster files was opened successfully'
SolZen = glob.glob(d4 + os.sep + "*.SolarZenith-SolarZenith.tif")
SolZen.sort()
if SolZen is None:
    print 'Could not open the SolZen raster files'
    sys.exit(1)
else:
    print 'The SolZen raster files was opened successfully'
SolAzm = glob.glob(d4 + os.sep + "*.SolarAzimuth-SolarAzimuth.tif")
SolAzm.sort()
if SolAzm is None:
    print 'Could not open the SolAzm raster files'
    sys.exit(1)
else:
    print 'The SolAzm raster files was opened successfully'
#Call MOD09 images from directory
d5="F:\\DB_test_data\\VAR2\\IDL\\MOD09\\"
Sur_B1 = glob.glob(d5 + os.sep + "*.500m_Surface_Reflectance_Band_1-500m_Surface_Reflectance_Band_1.tif")
Sur_B1 .sort()
if Sur_B1  is None:
    print 'Could not open the Sur_B1  raster files'
    sys.exit(1)
else:
    print 'The Sur_B1 raster files was opened successfully'
Sur_B2 = glob.glob(d5 + os.sep + "*.500m_Surface_Reflectance_Band_2-500m_Surface_Reflectance_Band_2.tif")
Sur_B2 .sort()
if Sur_B2  is None:
    print 'Could not open the Sur_B2  raster files'
    sys.exit(1)
else:
    print 'The Sur_B2 raster files was opened successfully'
Sur_B3 = glob.glob(d5 + os.sep + "*.500m_Surface_Reflectance_Band_3-500m_Surface_Reflectance_Band_3.tif")
Sur_B3 .sort()
if Sur_B3  is None:
    print 'Could not open the Sur_B3  raster files'
    sys.exit(1)
else:
    print 'The Sur_B3 raster files was opened successfully'
Land_cover="F:\\DB_test_data\\MCD12C1\\LAND_COVER_TYPE_1_Grid_2D.img"
if Land_cover  is None:
    print 'Could not open the Land_cover raster files'
    sys.exit(1)
else:
    print 'The Land_cover raster files was opened successfully'
    #print OutRaster
    #print OutRaster
    #TOA_B1 scalling
    #print OutRaster
    #TOA_B2 Scalling
    #print OutRaster
    #Height
    height=ras
    #print OutRaster
    #print OutRaster
    #print OutRaster
    #print OutRaster
    #print OutRaster
    #print OutRaster
    #print OutRaster
    #print OutRaster
JoeBorgione
Sorry, I just don't have the time to wade through your code; I've hundreds of lines of my own code I'm wading through.  My I suggest you study what you've done and execute the code block block until you find what giving you the error.
BIJOYGAYEN
Thank you, sir, for your suggestion. But sir can explain why this error occurs in this case?
JoeBorgione
Sorry, I can't without doing what I suggested. You've got your code in a modular fashion; my personal preference is to take what you've got so far and make them into their own functions or defs().  That way you can call each one in order from the main() function. Makes trouble shooting a bit easier as you can turn them on and off in main() and see where the error occurs.  I also like to bracket any geoprocessing functions within Try/Except blocks with print statements that tell you where things went wrong, if they do.  Here's an example of one I working on today:
def mergeClientToDelivery():
    outWS = 'in_memory'
    sourceTable = '{}\\ClientSum2'.format(outWS)
    targetTable = '{}\\Deliveries'.format(outWS)
    sourceFields = ['Zipcode','ClientCount']
    targetFields = ['Zipcode', 'ClientCount']
    #create dictionary....
    clientDict = {r[0]:(r[1]) for r in arcpy.da.SearchCursor(sourceTable,sourceFields)}
    #use the dictionary to update the deliveries table...
    try:
        with arcpy.da.UpdateCursor(targetTable,targetFields) as updateCursor:
            for updateRow in updateCursor:
                keyValue = updateRow[0]
                if keyValue in clientDict:
                    updateRow[1] = clientDict.get(keyValue,[0])
                    updateCursor.updateRow(updateRow)
        print('Success: mergeClientToDelivery updated fields in deliveries table in memory')
    except Exception as err:
        print('Error: mergeClientToDelivery could not update deliveries table in memory')
        print(err)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
BIJOYGAYEN
Thanks for your suggestion.
BIJOYGAYEN
Sorry, I am not able to solve this problem. If any know the way to solve the problem, then please suggest me regarding this code.
BIJOYGAYEN
I just Want to ask one question to Esri python developer, there is no option to solve my issue?
XanderBakker
Esri Esteemed Contributor
Hi BIJOY GAYEN ,
It would help to have access to some test data to see if the problem can be resolved. Without data it will be difficult.
