How can I delete specific Sent data - Survey123 Field App
1357
5
06-17-2019 06:34 AM
JeffDavis7
We are using the Survey123 field app to collect utility information using our Samsung 7 phones.
Is it possible to select one completed survey under the the "Sent" section and choose to delete without deleting all the other sent surveys?
It appears the only option is to "Empty" which clears everything out.
Thank you.
Jeff
BrandonArmstrong
Hi Jeff,
At the moment, it is not possible to remove individual surveys from the 'Sent' folder.  You can completely disable the Sent folder, using the 'Sent Surveys' tab in the Settings for the survey within Survey123 Connect.  Can you please share the workflow which would benefit from being a able to clear individual surveys from the Sent folder?
Brandon
JeffDavis7
Hi Brandon,
Thank you for your comment.
The workflow is essentially one of "tidying up".  We were testing our connections with Integromat and have some surveys that were only test runs mixed in with live runs.
Thanks.
Jeff
BrandonArmstrong
Thank you for providing that info, Jeff.  I've gone and added this request to our internal repository to be considered as a future enhancement for the field app.
Best,
Brandon
JeffDavis7
Thank you, Brandon.
Jeff
ScottFierro1
Brandon Armstrong‌ we would like to second this item. Here is a simple example of this source of confusion for users.
User submits a Survey on 5/11 but it’s bad. Team deletes the bad Survey from the back end. User re-submits a good Survey for 5/11. User goes into Sent box on device and sees both Surveys. Raises concerns for field staff on whether the good Survey is there and being used.
