How to calculate the length of polygons?
15509
8
06-10-2019 02:55 AM
EDpw
Hi all,
I am looking for a tool that would allow me to draw a line in the middle of polygons to calculate the total length of my polygons. I do not have access to the tool 'polygon to centreline'. I would like to avoid drawing the line in the middle of each individual polygon. I received the shapefile with more than 2800 polygons.  Any ideas?
Thank you for your help!
Best,
Elise
DanPatterson_Retired
That is the tool to use.
You could see if there are any implementations in python for 'medial axis' or 'polygon skeleton', but I suspect that you won't find any that can be easily implemented in a script
As an after thought
Minimum Bounding Geometry—Data Management toolbox | ArcGIS Desktop
one of the rectangle variants since they provide axis information.
Might suffice if your polygons are fairly regular.
JoshuaBixby
MVP Esteemed Contributor
I am not totally clear what definition of length you are thinking of for your polygons.  If you grab the extent for each polygon, that will give you the maximum and minimum Xs and Ys, which is one way of figure out width and height, depending on what you are interested in calculating.
Joshua, that works if the polygons are axis oriented.  For oriented, quasi-regular polygons, the quick minimum area bounding rectangle or what esri calls the 'rectangle by width' are good approximations.  For completely irregular or tortuously shaped polygons (ie picture a snake), the medial axis or polygon skeleton are approaches.  These can be derived through polygon triangulation or incremental negative buffers until you are left with intersection points as the polygon devolves to points... connect the points and you have an approximation of the internal 'axial line' of the polygon
JoshuaBixby
Agreed.  It isn't clear an axial definition is exactly what he is after, although he does reference the polygon to centerline tool, so he likely is.
EDpw
Thank you for your help Joshua Bixby and Dan Patterson
I will try to the polygon skeleton and medial axis approaches. My polygons are a mix between regular shapes and irregular shapes.
JohnWatt
Hi Elise. To achieve this in ArcGIS for a river centreline, I've used the Create Thiessen Polygons tool.  If you convert the polygons to lines, then split the lines into small segments (the smaller the segment, the smoother the centre-line), then create points from the line segments - creating Thiessen polgons from these points will create a centre-line in the middle for any irregular polygon - albeit with a bit of superfluous geometry.
I had to manually edit to leave only the centre-line, but there might be a way to do this without manually editing.  Which you'll need with over 2800 polys 🙂
John, that is the polygon triangulation method mentioned here
https://community.esri.com/thread/235082-how-to-calculate-the-length-of-polygons#comment-857416
to continue your process you
  • peel off the outer edges of the rings
  • repeat the above from its result
  • take the midpoint of edges of those edges whose start and end point are on the remaining shell
  • the remaining is the skeleton as either edges or points
  • devolve to points, connect as a polyline
