Search Widget not working
4085
06-06-2019 11:25 AM
JamesAgidius
I have been working on this application, (using the Javascript API), but I have encountered a slight problem.
One of the widgets (Search Widget with multiple sources) doesn't seem to function, although it is present/visible (all of the other widgets seem to be working as intended).
I see no errors in fiddler or console, but it definitely doesn't search..
I am not very proficient, and I was wondering if anybody might have any insight? I have attached the entire file (below) in the hopes that somebody might have the time to take a look.
Thank you in advance.
-James
RobertScheitlin__GISP
James,
  Your issue is that the sources property is called layer and not featureLayer anymore as it was in previous versions.
var searchWidget = new Search({
        view: view,
        includeDefaultSources: false,
        locationEnabled: false,
        sources: [{
          layer: Parcels,
          searchFields: ["PM_PAR_14"],
          displayField: "PM_PAR_14",
          exactMatch: false,
          outFields: ["PARCEL_ID"],
          placeholder: "example: RP40N02W162502",
          layer: Parcels,
          searchFields: ["PM_MAIL_NM"],
          displayField: "PM_MAIL_NM",
          exactMatch: false,
          outFields: ["PM_MAIL_NM"],
          name: "Last Name, First Name",
          placeholder: "example: Doe, John",
          layer: Addresses,
          searchFields: ["FULLADDRSS"],
          exactMatch: false,
          outFields: ["*"],
          layer: Actions,
          searchFields: ["LABEL"],
          exactMatch: false,
          outFields: ["*"],
          name: "Land Use Action",
          featureLayer: Divisions,
          searchFields: ["LD_Number"],
          exactMatch: false,
          outFields: ["*"],
          name: "Land Division",
James,
        view: view,
        sources: [{
          layer: Parcels,
          exactMatch: false,
          layer: Parcels,
          exactMatch: false,
          layer: Addresses,
          exactMatch: false,
          outFields: ["*"],
          layer: Actions,
          exactMatch: false,
          outFields: ["*"],
          exactMatch: false,
          outFields: ["*"],
JamesAgidius
Thank you Robert. That did the trick.
James,
   No problem. Normally you would want the mark the reply that answered your question as the correct answer and not your reply to my correct answer.
