WebForm: Error 1500 Incorrect Geometry
305
06-04-2019 01:06 PM
by Anonymous User
Not applicable
I am building a widget that opens Survey123 pre-populated with results from queries.  This has been working fine with Survey123 Desktop field app.  Today, I read that the webform got some updates, so I switched my widget to open the webform instead.  Pre-population works fine but submission errors out with two "operation rolled back" and one "incorrect geometry" message. I am attaching the error message screenshot.
I am trying to add to existing features service (point), so I am not sure why it shows what I am passing is incorrect geometry.  If I change the same URL just to open the desktop app, it submits without error.  What can be possibly causing the error in the webform?
JamesTedrick
Esri Esteemed Contributor
Hi Ahjung,
It looks like the form you are using has repeats - are you trying to populate a value in the repeat section?
by Anonymous User
Not applicable
James, I no longer have repeats in my form but I am still getting the same error.  This looks like a similar issue as mine.
