Is it possible to view polygon features in the Survey123 inbox map view?
1277
05-28-2019 10:55 AM
MichaelaParadis1
I have been using Survey123 connect to edit existing hosted feature layers in Survey123. Given that the inbox is enabled, I am able to see records in the list section of the inbox. That being said I have noticed that when using a polygon feature layer, the map does not show any features.
If I choose one of the records in the list, and the geoshape is enabled when creating the survey the polygon in question comes up on the map, in the survey itself. However, as mentioned in the inbox map view no polygons are appearing.
I tested this process with a point feature layer and it did show up on the map.
I am wondering if it is not possible to see polygons in the inbox map view on survey 123 when editing existing hosted feature layers, or if there is something I am missing to enable this?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Michaela,
Currently Survey123 does not support polygons; that being said, polygon and line collection is in beta and Inbox display of these features is planned as part of releasing that feature.  We anticipate release of polygon/line support later this year.
