Dynamic map frames data series
2405
05-27-2019 06:24 AM
MadeleneSonesson
I am making a data series that is based on a grid over Sweden. Every page of the data series should include two data frames: the actual map extent of that part of the grid and a reference to where in Sweden that part of the grid is located. I want to make that second map frame dynamic in the same aspect as the primary one, i.e poiting to that attribute that sorts the pages. How do I do that?
TomBole
Hi Madelene,
You can drive the extent of your map frame by setting a constraint see https://pro.arcgis.com/en/pro-app/help/layouts/customizing-your-map-extent.htm.  Look to the bottom half of the help topic for information about  working with a map series.
Hope this helps,
Tom
TomBole
Hi Madelene,
Hope this helps,
Tom
MadeleneSonesson
Thank you Tom, this was exactly what I was looking for.
