Upgrading Workstation
7814
12
05-08-2019 09:51 AM
JamesStewart-Moore1
I have a budget of about $1,000 to upgrade my current workstation, and I would appreciate any input from the community on where my money will be best spent. I currently use ArcMap 10.6 to do all of my processing, however, I am planning to eventually migrate to using the 64-bit ArcPro (once I stop resisting change).
The majority of my work involves using the 3D Analyst and Spatial Analyst extensions. I do a lot of LiDAR processing, including ".lasd to raster", as well as using raster calculator expressions to generate subsequent products.  These rasters are on the order of 10 GB in size, sometimes larger. Currently, my processing times seem long, i.e. ".lasd statistics to raster" might take 8 hours. Also, my drawing/rendering time is quite long. When I have a feature such as contours for a large area, it can take 30 seconds or so for the entire layer to render each time the frame is moved.
My Current Workstation:
Dell T5810
Xeon E5-1603 v3 @2.8 GHz
8.0 GB 2133 MHz DD4 RAM
NVIDIA Quadro K420
256 GB HD (connected to network with  20 TB)
My thoughts are to upgrade to 32 or 64 GB of RAM and update the graphics card. From what I understand, the NVIDIA quaddro line is well suited to Arc. I have been looking at the Quadro K2200, but I am open to suggestions if there are better ones out there.
Where would you spend the $1,000?
DEWright_CA
You can never go wrong with more RAM; that is a great place to consider. Also consider the HDD; since Arc using a fGDB for it's scratch space the more you have that is faster (SDD) gives you some good flexibility.
ThomasColson
Don't waste the money! That E5-1603 belongs in a museum! I'm guessing your IT/chain of command is telling you that budget #. Point out to them if they want you to continue to be able to do your job....
Here's what I got recently for about 12 folks, there was a LOT of discussion with management and IT about the cost, and where we landed was an intelligent and meaningful conversation between management and GIS about what expectations management had about what GIS was going to do for them in the future, or not. What worked well for me was a detailed spreadsheet of Pro Performance on the current workstation, the rate at which Pro min hardware requirements increases (which is high), and a multiplier on top of that as Pro min requirement do not translate to a workstation that will actually do things like Lidar Processing, a return on investment calculation....I really put a lot of effort into convincing the chain of command what I thought we needed and in the end I got more than I asked for, and I've put a lot, lot of time into testing Pro and hardware in a realistic production environment that utilizes almost every Pro component. We set a target life span of these new workstation of 3 years, and in order to get them in service I actually had to volunteer at IT on my off days to get them imaged, as management thinks IT has nothing to do and cut one of their positions, the workstations would have sat there for a year otherwise. My hope is I might be able to get another "Pro" year or two on them with some small memory upgrades. I'm also having more frequent discussions with middle management to make sure they are programming GIS workstation budget into their 3 and 5 year budget plans for their employees that have GIS as assigned duties, where previously we programmed GIS workstations into the "If there's anything left at the end of the year" account.
For real, I wouldn't put money into your existing antique. You're not going to be happy with it and Pro in 18 months, and your boss (or you) is going to be wondering about the quality of your budget advice. Your problems are a direct result of the age of the motherboard, lack of physical/virtual cpu cores, slow memory and bus speed, and 5000$ in upgrades aren't going to make those things any better. That memory speed is pretty low, and I don't think you can go to a higher frequency on that motherboard, so even with 64 GB of ram, it's going to be bottlenecked at the CPU bus. That video card is a dinosaur too, it's a geriatric 5 years old in the Pro universe, I don't have that model but I have had ESRI tell me another NVIDIA model was on the rails of "not supported" and it was a high-end, 5 year old card. So that splits your budget, 200-ish for a new vid card, 2-400 for memory, and leftover for a SSD, which in the end will result in ".lasd statistics to raster" might take 8 hours" shortening to "".lasd statistics to raster" might take 7 hours 55 minutes."
My two cents: Beg for the money for a new workstation, and re image your current one. Re imaging might get you into ".lasd statistics to raster" might take 6 hours."
eQuote Details
Description
Quantity
Price
| OptiPlex 7060 MT
$3,089.77
Premier discount
$1,019.62
____________
$2,070.15
Module
Description
Product Code
Sku
ID
OptiPlex 7060 MT
Optiplex 7060 Mini Tower XCTO
GEL2Q5H
[210-AOKJ]
Processor
Intel Core™ i7-8700 (6 Cores/12MB/12T/up to 4.6GHz/65W); supports Windows 10/Linux
GVT4H1R
[338-BNZW]
146
Operating System
Ubuntu Linux 16.04
G3E9WNP
[605-BBNH]
11
Microsoft Application Software
No Productivity Software
GEKH8UQ
[630-AAPK]
1002
Memory
64GB 4X16GB 2666MHz DDR4 UDIM Non-ECC
GY4K0NG
[370-AEBU]
Hard Drive
M.2 256GB PCIe NVMe Class 40 Solid State Drive
G24H537
[400-AWFT]
[773-BBBC]
8
Additional Hard Drive
No Additional Hard Drive
G780XKR
[401-AANH]
637
Video Card
AMD Radeon™ RX 550, 4GB, FH (DP/mDP/mDP)
G3YO86R
[490-BEFU]
6
CD ROM/DVD ROM
8x DVD+/-RW 9.5mm Optical Disk Drive
G589BYA
[325-BCXM]
[429-ABFH]
16
Additional Storage Devices - Media Reader
Media Card Reader
GQ5X8Z6
[385-BBNG]
10
Wireless
No Wireless LAN Card
GE7Y41P
[555-BBFO]
19
Driver
No Wireless
GVHB6TP
[555-BBFO]
7
PCI Card
USB Type-C 3.1 Gen 2 PCIe Card (Full Height)
GGFP90O
[382-BBFQ]
698
Chassis Options
OptiPlex 7060 Tower with 260W up to 85% efficient Power Supply (80Plus Bronze)
G67A9OF
[329-BDSK]
116
Keyboard
Dell KB813 Smart Card Keyboard (US)
GNR9U8H
[580-AFDH]
Mouse
Dell USB Laser 6-Button Mouse
GVN0A53
[570-AACQ]
12
Back Cover
No Cover Selected
GKN16CQ
[320-BCGK]
376
Cables and Dongles
No Adapter
GKRDEM4
[470-AAJL]
592
External Speakers
No External Speaker
GTNM7E2
[817-BBBC]
200095
Non-Microsoft Application Software
No Additional Operating System Software
G9RTEX8
[640-BBJD]
[658-BDVQ]
1003
Operating System Recovery Options
OS-Windows Media Not Included
GLA9OQ1
[620-AALW]
200013
E-Star
Energy Star
G6J34SM
[387-BBLW]
122
Raid Connectivity
No RAID
GS3UFWA
[817-BBBN]
1009
Network Card
No Network Card
G9MQCN3
[555-BBJO]
13
FGA Module
No FGA
NOFGA
[817-BBBB]
572
Placemat
MOD,PLCMT,QSG,7060,MT,DAO1
GR0FOKM
[340-CDYY]
60
Systems Management
Intel® vPro Technology Enabled
GFTZC4U
[631-ABQQ]
49
Protect Your New PC
No Security Software
NOSS
[650-AAAM]
1014
Optical Software
PowerDVD Software not included
GI5LS2C
[632-BBBJ]
597
TPM Security
Trusted Platform Module (Discrete TPM Enabled)
GJMDKT6
[329-BBJL]
297
Regulatory Label
Regulatory Label 7060 Mini Tower
GSX8752
[389-CXGK]
676
Processor Branding
8th Gen Intel® Core™ i7 vPro™ processor label
GJW1R0P
[389-CGJM]
749
Power Cord
System Power Cord (English)
GA5894N
[450-AAOJ]
20
Hard Drive Software
NO INTEL RESPONSIVE
GH8DSLC
[551-BBBJ]
707
CompuTrace Offerings + Stoptrack Label
No Computrace
GO1F2XY
[461-AABF]
697
UPC Label
No UPC Label
G8WGTYN
[389-BCGW]
292
Documentation/Disks
Safety/Environment and Regulatory Guide (English/French Multi-language)
G7RB0GY
[340-AGIK]
21
Canada Ship Options
US No Canada Ship Charge
G3IA0L8
[332-1286]
111
Packaging
Ship Material for OptiPlex Tower
G7G214X
[340-CDWT]
[389-BBUU]
465
Additional Video Ports
Additional DisplayPort for Tower
GN4XQKA
[382-BBFU]
495
Transportation from ODM to region
Standard shipment
GQT8IGC
[800-BBIO]
200080
Hardware Support Services
4 Years Hardware Service with Onsite/In-Home Service After Remote Diagnosis
G5R3XB7
[812-3886]
[812-3889]
29
eQuote Subtotal
$2,070.15
Promotional Discounts*
$0.00
Shipping*
$0.00
Shipping Discount*
$0.00
Estimated Tax*
$0.00
eQuote Total*
$2,070.15
*The eQuote total, including applicable taxes and additional fees, may be viewable online.
And we got some laptops too:
eQuote Summary
Description
Quantity
Unit Price
Subtotal
Mobile Precision 5520
$2,646.79
$2,646.79
eQuote Subtotal
$2,646.79
$0.00
Shipping*
$0.00
Shipping Discount*
$0.00
Estimated Tax*
$0.00
Environmental Disposal Fee*
$0.00
eQuote Total*
$2,646.79
eQuote Details
Description
Quantity
Price
xctop5520hwtaa | Mobile Precision 5520
$3,950.43
Premier discount
$1,303.64
____________
$2,646.79
Module
Description
Product Code
Sku
ID
Dell Mobile Precision Workstations 5520
Dell Mobile Precision Workstation 5520 XCTOG
X5520TG
[210-AKNC]
Processor
Intel Core i7-7820HQ (Quad Core 2.90GHz, 3.90GHz Turbo, 8MB 45W, w/Intel HD Graphics 630)
I77820H
[379-BCRI]
146
Operating System
Ubuntu Linux 16.04
UBUNTU
[605-BBMN]
11
Office Productivity Software
NOPSW
[630-AAPK]
1002
Dell Data Security
No Dell Data Protection | Endpoint Security Suite Software
NODDP
[634-BENZ]
593
Video Card
Nvidia Quadro M1200 w/4GB GDDR5
NVIDIA
[490-BDQB]
6
LCD
15.6" UltraSharp™ FHD IPS (1920x1080) Wide View Anti-Glare LED-backlit w/Prem Pn Grnt, Non-touch
FHD
[391-BDBB]
760
Base Options
Intel Core i7-7820HQ w/Intel HD Graphics 630 for Win10 & Linux only
KDI7G
[329-BDGX]
149
Palmrest
Palmrest for English Keyboard
PLSTGSA
[346-BBTP]
55
Memory
32GB, DDR4-2400MHz SDRAM, 2 DIMMS
32G2D4
[370-ADHQ]
Primary Storage
M.2 PCIe 512GB SSD Class 50
512HP
[400-AOSN]
[412-AAHG]
8
Secondary Storage
NOHDDA
[401-AADF]
637
Keyboard
Internal Single Pointing Backlit Keyboard, English
KYBDGSA
[580-AEEY]
Wireless
Dell Wireless 1820 Card (802.11AC Dual-Band Wi-Fi + Bluetooth 4.2), 2x2
1820
[555-BDGM]
19
Primary Battery
6-cell (97Wh) Lithium Ion battery with ExpressCharge™
6C
[451-BCBU]
112
Power Supply
130w Power Adapter
AC130W
[470-ABVP]
[492-BBXM]
1015
Systems Management
No Out-of-Band Systems Management
NOVPRO
[631-ABEW]
49
Optimizer
No Optimizer
NOOPT
[640-BBQT]
372
No Media
NOMEDIA
[620-AAOH]
200013
Energy Efficiency Options
No External CD/DVD Drive
NONE
[817-BBBP]
122
Docking Station
NONE
[452-BBSE]
271
Documentation/Disks
EFDOC
[340-AGIK]
21
FGA Module
No FGA
NOFGA
[817-BBBB]
572
Packaging
SHUTTLE Ship Material
TSHTLE
[328-BCLP]
[340-ARFJ]
465
Placemat
No Quick Reference Guide
NOTSH
[340-AASE]
60
Standard Shipment
STND
[800-BBGS]
200080
Driver
Dell Wireless 1820,5520
1820
[555-BDIH]
7
Carrying Cases
No Carrying Case
NONE
[460-BBEX]
118
Processor Branding
Intel® Core™ i7 Label
CI7SML
[389-BLST]
749
Support Tech Sheet and Powercord
No UPC Label
NOLBL
[389-BCGW]
292
UBUNTU
UBUNTU
[640-BBQQ]
1003
Mouse
No Mouse Selected
NOMSE
[570-AADK]
12
TAA
Information
DIRSHIP
[379-BBBW]
97
Label
Regulatory Label Included
REG
[389-BEYY]
676
Stands and Mounts
No Stand
NOSTND
[575-BBCH]
558
Canada Ship Options
USNONE
[332-1286]
111
Diagnostic CD / Diskette
No Resource DVD
NRDVD
[340-ADBJ]
50
Cable
US Power Cord
US25A
[537-BBBD]
20
3 Year Hardware Service with Onsite/In-Home Service After Remote Diagnosis
NBD3
[804-9773]
[804-9778]
29
Removable CD/DVD Drives
NONE
[429-AATO]
105
eQuote Subtotal
$2,646.79
$0.00
Shipping*
$0.00
Shipping Discount*
$0.00
Estimated Tax*
$0.00
eQuote Total*
$2,646.79
JamesStewart-Moore1
I am actually the one who came up with the budget. I work in a small geotechnical engineering firm and am a geologist by profession, but I happen to use Arc for the majority of my work. The owner of the company is my direct boss, so getting him to OK something that will help the company save time/money should not be an issue. I think that a system of ~$3k is something that I could easily propose without much resistance.
I am curious why you went with an i7 over a Xeon? Was this simply due to the budget you had to work with?
I am looking at a configuration of this system:
https://www.dell.com/en-us/work/shop/workstations-isv-certified-dell/precision-5820-tower/spd/precis...
likely spending the $135 to upgrade to the Xeon X-W2135 for the 6 cores. The system comes standard with NVIDIA Quadro P4000.
Thoughts?
DEWright_CA
Working in a Engineering firm; you might be using more than just Arc on the machine; so going with the Xeon would be my recommendation (former Site/Civil Designer in AutoCAD & Microstation). There are plenty of places where the higher cache capacity and higher command-sets are used in software.
ThomasColson
In that case:
List Price$5,227.29
Total Savings$1,576.59
Dell Price$3,650.70
Dell Business Credit
As low as $110/mo.^ | Apply
Get it by May 15-20 with Express Delivery
Customize
OptionSelectionSKU / Product CodeQuantity
Processor
Intel Xeon W-2133 (3.6GHz, 3.9GHz Turbo, 6C, 8.25MB Cache, HT, (140W)) DDR4-2666[338-BNBN][412-AALF] / W21331
Operating System
Windows 10 Pro for Workstation (4 Cores Plus) Multi - English, French, Spanish[619-AMSU] / 10P6T2M1
Microsoft Office 365 (Word, Excel, Powerpoint, Outlook & more)
None1
Microsoft Office
Microsoft Office 30 Day Trial[658-BCSB] / 16MUI1
Chassis Options
Precision 5820 Tower 950W PCIe FlexBay Chassis[321-BDWC] / G5879SN1
Graphics Card
NVIDIA® Quadro® P4000, 8GB, 4 DP (5820T)[490-BEBH] / P40001
Memoryi
32GB 2x16GB DDR4 2666MHz RDIMM ECC[370-ADVE] / 32G2161
Systems Management
No Out-of-Band Systems Management[631-ABML] / NOVPRO1
Wireless
No Wireless LAN[555-BBNI] / GW1SM6D1
Operating System (Boot) Drive
Intel NVMe PCIe SSD (Front PCIe FlexBay)[414-BBBV] / FFPCIE1
Hard Drive Controllers
Intel Integrated controller (RST-e) with 1-2 Front FlexBay NVMe PCIe Drives,v2[321-BDWI] / GCDH8PJ1
Hard Drive
M.2 512GB PCIe NVMe Class 50 Solid State Drive[400-AVDR][401-ABGX] / 512C5ME1
2nd Hard Drive
No Hard Drive[400-AKZR] / NOHDD1
Lockable HDD/SSD Sleds
None1
3rd Hard Drive
4th Hard Drive
Slimline Bay Options
Slim filler panel (no opt.)[429-ABEP] / NOSLODD1
Optical Drive
No Optical[429-ABER] / NOODD1
5th Hard Drive
6th Hard Drive
RAID for HDD/SSD & Front PCIe NVMe SSDs
No RAID[780-BBCJ] / NORAID1
Dell Ultra-Speed Drives (PCIe SSDs)
None1
RAID Configurations for Dell Ultra-Speed Drives
None1
Keyboard
No Keyboard[580-ABIS] / NKB1
Mouse
No Mouse[570-AADK] / NMSE1
Teradici Remote Workstation Access Host Card
No Remote Access Host Card[340-ADBJ] / NHSTCRD1
Network Cards
No Add-In Network Card (Integrated NIC only)[555-BBJO] / NONIC1
PCIe I/O Cards
Not Selected in this Configuration[817-BBBC] / NOTHB1
Serial Port/PS2 Adapter
Full Height Serial Card[492-BCGW] / SERCDFH1
Power Cords
US 125V Power Cord[470-AAKG] / USPWR1
Resource DVD
Resource DVD not Included[430-XXYU] / NORDVD1
OS-Windows Media Not Included[620-AALW] / NOMEDIA1
E-Star
No Energy Star[387-BBBE] / NOESTAR1
Optimizer
Dell Precision Optimizer[640-BBRC] / OPTMZR1
Optical Software
No Optical Software[817-BBBC] / NOSWODD1
Dell Endpoint Security
None1
Absolute Security - Standard
None1
Cables and Dongles
No Accessories[461-AABV] / NOACCES1
Security Software
No Security Software[650-AAAM] / NOSS1
Driver
UPC Label
No UPC Label[389-BCGW] / G8WGTYN1
Support & Services
Warrantyi
3 Years ProSupport Plus with Next Business Day Onsite Service[997-7163][997-7232][997-7242][997-7252][997-7272] / PPN31
Accidental Damage
None1
Keep Your Hard Drive
None1
ProDeploy Client Suite
None1
HDD Partition - Standard
None1
Drop in Box Accessories - Standard
None1
Airwatch Application - Standard
None1
JamesStewart-Moore1
I really appreciate all the feedback. I went with this exact configuration except I went with the Xeon W-2145 for the 8 core upgrade. I was not aware that both ArcPro and Desktop versions 10 and later were true multi-core.
ThomasColson
So that's actually going to give you 16 virtual cores. I got dual 12 core xeons on my last workstation, having all those cores IMHO does more for Pro performance than memory.
DEWright_CA
Pro is fully multi-threaded and 64bit aware; ArcGIS Desktop (ArcCatalog/ArcMap) is 32bit and not multi-threaded aware; but you are able to fake it really well using python/georprocessing tools.
DEWright_CA
This is actually the config I have right now; but with Dual-Xeons as a cluster of 3 machines. Very nice platform.
