How to change field visibility and alias
2654
05-25-2019 04:44 PM
Suleyman-Arslan
I am trying to iterate layers and change visibility of fields in feature layers. I tryed to get "CIMFieldDescription" but it returns null when layer has default field descriptions.
Am I going in wrong way?
Tags (1)
UmaHarano
Hi
The best way to change the visibility of a field to use the IDisplayTable.
This code will set all the fields in a layer to be visible:
 var table  = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault() as IDisplayTable;
            QueuedTask.Run( () => {
                var fieldDescriptions = table.GetFieldDescriptions();
                foreach (var field in fieldDescriptions)
                    field.IsVisible = true;
                table.SetFieldDescriptions(fieldDescriptions);
Uma
Suleyman-Arslan
I used following code to change visibility but nothing changed on layers.
Map pmap = await FindOpenExistingMapAsync(tb_Map.Text);
List<BasicFeatureLayer> featureLayerList = pmap.GetLayersAsFlattenedList().OfType<BasicFeatureLayer>().ToList();
listView1.ItemsSource = pmap.GetLayersAsFlattenedList().OfType<BasicFeatureLayer>().ToList();
foreach (BasicFeatureLayer fl in featureLayerList)
   await QueuedTask.Run(() =>
      foreach (FieldDescription fd in fl.GetFieldDescriptions())
            fd.IsVisible = true;
         fd.Alias = myconfig.Alias;
UmaHarano
Hi
Uma
Suleyman-Arslan
Thank you for your help.
Your code help me to find out my mistake. My code worked by adding code "fl.SetFieldDescriptions(fieldDesc);"
                    var fieldDesc = fl.GetFieldDescriptions();
                    foreach (var fd in fieldDesc)
                        fd.IsVisible = myconfig.Visible;
