I am trying to iterate layers and change visibility of fields in feature layers. I tryed to get "CIMFieldDescription" but it returns null when layer has default field descriptions.
Am I going in wrong way?
Hi
The best way to change the visibility of a field to use the IDisplayTable.
This code will set all the fields in a layer to be visible:
<SPAN class="keyword token">var</SPAN> table <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetLayersAsFlattenedList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>OfType<SPAN class="operator token"><</SPAN>FeatureLayer<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> IDisplayTable<SPAN class="punctuation token">;</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> fieldDescriptions <SPAN class="operator token">=</SPAN> table<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFieldDescriptions</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> field <SPAN class="keyword token">in</SPAN> fieldDescriptions<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> field<SPAN class="punctuation token">.</SPAN>IsVisible <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> table<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetFieldDescriptions</SPAN><SPAN class="punctuation token">(</SPAN>fieldDescriptions<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks
Uma
I used following code to change visibility but nothing changed on layers.
Map pmap = await FindOpenExistingMapAsync(tb_Map.Text);
List<BasicFeatureLayer> featureLayerList = pmap.GetLayersAsFlattenedList().OfType<BasicFeatureLayer>().ToList(); listView1.ItemsSource = pmap.GetLayersAsFlattenedList().OfType<BasicFeatureLayer>().ToList();
foreach (BasicFeatureLayer fl in featureLayerList) { await QueuedTask.Run(() => { foreach (FieldDescription fd in fl.GetFieldDescriptions()) { fd.IsVisible = true; fd.Alias = myconfig.Alias; }
Thank you for your help.
Your code help me to find out my mistake. My code worked by adding code "fl.SetFieldDescriptions(fieldDesc);"
Map pmap = await FindOpenExistingMapAsync(tb_Map.Text); List<BasicFeatureLayer> featureLayerList = pmap.GetLayersAsFlattenedList().OfType<BasicFeatureLayer>().ToList(); foreach (BasicFeatureLayer fl in featureLayerList) { await QueuedTask.Run(() => { var fieldDesc = fl.GetFieldDescriptions(); foreach (var fd in fieldDesc) { fd.IsVisible = myconfig.Visible; fd.Alias = myconfig.Alias; } fl.SetFieldDescriptions(fieldDesc); }); }
Signed in members can post, follow updates, and more. New here? Register a free account.
