Is it possible to create dimensions with python code?
1310
05-26-2019 11:45 AM
GARYLESTER
I am wondering if it is possible to create dimensions in arcmap with python, arcmap version 10.7. I have looked and I see functions to list dims but not  create them.
Also when I create a dimension in esri dimension feature class the dimensions are gone when I reopen the map I get error "can not initialize COM object" then has layer name for dimension layer.
DanPatterson_Retired
You have this posted in ArcGIS Pro, but mention ArcMap
For Pro, these are the access points to dimensions
Dimensions in ArcGIS Pro—Dimensions | ArcGIS Desktop
Arcpy can be used to run tools in ArcToolbox, if the process involves wizard, then no.
If a tool in arctoolbox exists, then there will be a code sample at the end of the help topic for the tool.l
