Data Drive Pages/Map Series in Map Tab
1750
05-21-2019 08:54 AM
BlaineHackett2
I use ArcMap often with Data Drive Pages to help perform manual change detection.  It works really well in the ArcMap data view to move along a grid methodically.  When creating the map series in ArcPro, it seems that only works in the Layout Tab and does not afford me the same functionality.  Am I missing something or is that the only way it works in ArcPro?
TomBole
Hi Blaine,
In ArcGIS Pro the Map Series is defined for the Layout. A Map Series cannot be "linked" to a map view.
If you are simply using the index layer to move about the Map View (as opposed to doing the same thing in the Layout View) you can open a Table View of the index layer, dock it next to the Map View, right click the index layer feature you want to zoom to, right-click and choose "Zoom To".
Hope this helps,
Tom
BlaineHackett2
Hi Tom! Yes, thanks for the suggestion.  Unfortunately, not as quick as the data driven maps solution.  However, I have found a work around.  You can create Bookmarks in the Layout Tab and use them in the Map Tab.  So I was able to use a similar workflow.  However, there is no way to export Bookmarks from Pro as you can from ArcMap so I am kinda stuck there.  Another topic for another day!
Best Regards,
Blaine
KoryKramer
Esri Community Moderator
The ability to export bookmarks will be in ArcGIS Pro 2.4, which will be available in about a month or so: https://community.esri.com/ideas/12759-exportimport-bookmarks-in-arcgis-pro
