Synchronize Error
846
05-06-2019 09:40 AM
SeanRedar
I used create_replica to successfully create a replica between to GISs but cannot get the subsequent sync using the sync_replicated_items.  Traceback shows an "HTTP Error 498" which eludes to the service URL not being passed a token.  There is a subsequent error but that appears to be related to the first.  Both GISs are AGOL based and am using the current API on my ArcPro install, v1.5.
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 831, in get
resp = opener.open(url)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 532, in open
response = meth(req, response)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 642, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 570, in error
return self._call_chain(*args)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 504, in _call_chain
result = func(*args)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\urllib\request.py", line 650, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 498: 498
During handling of the above exception, another exception occurred:
File "D:\Temp\test.py", line 33, in <module>
sync_extint = arcgis.features.FeatureLayerCollection(ext_fs_url,extGIS).replicas.sync_replicated_items(ext_item,int_item,"NWD Levee Assessment")
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\managers.py", line 697, in sync_replicated_items
out_path=tempfile.gettempdir())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\layer.py", line 2347, in _synchronize_replica
token=self._token)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 906, in get
return self.get(newpath, ssl, try_json, is_retry=True)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py", line 798, in get
params['f'] = 'json'
TypeError: 'bool' object does not support item assignment
