Missing fonts in ArcGIS Pro
10358
10
05-06-2019 05:47 AM
JohnMacKinnon
I am using a custom style set to symbolize point features that references a custom font file (.ttf), which is installed on my PC.
Everything displays properly in Arc Map 10.5.1, but inside ArcGIS Pro 2.1.1 the same font file is not available when I import the custom style set and apply the symbology or import an existing mxd into ArcGIS Pro. The style set applies default characters as if the font file is not installed.
A) Does ArcGIS Pro reference all fonts installed on you PC in the same manner as Arc Map?
B) Are custom font files not permitted in ArcGIS Pro?
DanPatterson_Retired
ArcGIS Pro apparently, checks the windows font folder and...
C:\Your_Install_path_to_Pro\Resources\Fonts
folder, Try copying the missing fonts to there and see if they are accessable
SaratogaPLAN
Where do I find the font file to copy?
JohnMacKinnon
That worked, Thanks Dan
Glad it worked out John
FelixMcCarthy
Worked for me as well - Thanks.
LizJuers
Worked for me too! Thank you! Does not seem like Pro is pulling from the windows font folder correctly.
PeteJordan
Yes, this finally solved my issue with Highway Fonts not working in Pro...
textandfonts
Hi, Can you please tell me about the below things:
https://community.esri.com/t5/arcgis-pro-questions/missing-fonts-in-arcgis-pro/m-p/648453/
I will be happy to get help from you in releasing this confusion. Thanks in advance
Bo_King
Esri Alum
Hi @textandfonts
The original question you reference was answered in the comments above.
Link to solution above:   Solved: Re: Missing fonts in ArcGIS Pro - Esri Community
