Conditional Formatting in a Indicator Widget
2266
5
04-29-2019 10:00 AM
by Anonymous User
Not applicable
I am working with an indicator widget and I can get conditional formatting to work above and below the value, but when the percent change is "0" I want to be able to have the indicator show a grey color instead of the red that indicates an increase. It looks like the widget only allows for 2 conditional formatting options.  Does anyone know how to add the third?
Tags (1)
HayleyHume-Merry
Hi Lesley,
Did you ever work this one out? I'm also looking at doing the same.
Cheers
Hayley
by Anonymous User
Not applicable
Hi! Nope. I was hoping someone would be able to help. Not yet....
Lesley
NataliyaLys
JamieLambert
I would like  to see this also.
Positive Change, Negative Change, No Change.
It would also be good to set a tolerance on the No Change option. For example, if a value is within a tolerance (say +/- 5) it is shown as 'No Change'.
To have Increase or No Change lumped together can be very misleading!
Any information about this functionality? Derek LawDavid Nyenhuis‌ ? Thanks.
DerekLaw
Esri Esteemed Contributor
Hi Jamie,
Sorry for the late reply, I was out of the office on vacation.
> Indicator element - It would also be good to set a tolerance on the No Change option. For example, if a value is within a tolerance (say +/- 5) it is shown as 'No Change'.
As David Nyenhuis‌ stated in the other thread referenced by Nataliya Lys, this capability is currently not available in Ops Dashboard. Please submit an enhancement in the ArcGIS Ideas for Ops Dashboard site.
Hope this helps,
