Create Dialog Box Dynamically,Get user input values and Add Text Graphics on Map ?
3651
04-24-2019 01:47 AM
MayurDodiya
I have requirement to add text graphics on Map. User will click on Draw tool and then click on Map, When user click on Map open the dialog window like below.
User will enter text and chose color(Red, Black) from drop down and when click on save button get values of textbox and drop down selected value and add text on Map.
I am able to add text Graphics on Map without dialog box, but I am not getting how to create Dialog dynamically like above screenshot, fire event of Save button and when you click on save button add text graphics on Map.
Below is my code to add text graphic without dialog box.
drawText: function () {
var drawTextClickHanlder = this.map.on('click', lang.hitch(this, function (evt, override) {
var textSymbol = new TextSymbol(
"Text",
 this.textFont,
 this.textColor
 var textGraphic = new Graphic(evt.mapPoint, textSymbol);
 this.textGraphics.add(textGraphic);
 this.connectMapClick();
 drawTextClickHanlder.remove();
RobertScheitlin__GISP
Mayur,
   Here is a sample that shows that:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>Label</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.11/esri/themes/light/main.css" />
  <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/4.11/dojox/layout/resources/FloatingPane.css" />
  <script src="https://js.arcgis.com/4.11/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .dojoxFloatingPaneTitle .dijitTitleNode {
      padding-left: 5px;
      color: white;
    .dojoxDock {
      display: none;
    .dojoxFloatingPaneTitle,
    .dojoxFloatingPane {
      border: #88165b;
      background: #88165b;
      height: 25px;
    #entryDiv {
      padding: 8px;
      float: left;
    .formLbl {
      float: left;
    .formLine {
      width: 100%;
      padding-bottom: 8px;
  </style>
  <script>
    let efp;
    require([
      "esri/views/draw/Draw",
      "esri/Map",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/Point",
      "esri/views/MapView",
      "esri/symbols/TextSymbol",
      "dojo/dom",
      "dojox/layout/FloatingPane",
      "dojo/domReady!"
    ], function (Draw, Map, Graphic, GraphicsLayer, Point, MapView, TextSymbol, dom, FloatingPane) {
      const textGraphics = new GraphicsLayer();
      let drawPnt;
      const map = new Map({
        basemap: "streets",
        layers: [textGraphics]
      const view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 12,
        center: [18.06, 59.34]
      const draw = new Draw({
        view: view
      efp = new FloatingPane({
        title: "Enter Text",
        closable: false,
        resizable: true,
        dockable: true,
        style: "position:absolute;top:250px;left:350px;width:260px;height:300px;visibility:hidden;max-height:400px;",
      }, dom.byId("divFloatingPane"));
      efp.startup();
      view.ui.add("point-button", "top-left");
      document.getElementById("btnSave").onclick = function() {
        var textSymbol = new TextSymbol({
          text: dom.byId("LabelText").value,
          color: dom.byId("colorSelect").value,
          font: {  // autocast as new Font()
            family: "sans-serif",
            weight: "bold"
        var textGraphic = new Graphic(drawPnt, textSymbol);
        efp.hide();
      document.getElementById("point-button").onclick = function () {
        const action = draw.create("point", {
          mode: "click"
        view.focus();
        action.on("draw-complete", function (evt) {
          drawPnt = new Point({
            x: evt.coordinates[0],
            y: evt.coordinates[1],
            spatialReference: view.spatialReference
          efp.show();
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="point-button" class="esri-widget esri-widget--button esri-interactive" title="Draw label">
      <span class="esri-icon-map-pin"></span>
    </div>
    <div id="divFloatingPane">
      <div id="entryDiv">
        <div class="formLine">
          <div class="formLbl" for="LabelText" style="width:84px;">Enter Label</div>
          <textarea id="LabelText" style="width:152px;"></textarea>
        </div>
          <div class="formLbl" style="width:84px;">Color</div>
          <select id="colorSelect">
            <option value="red" selected="selected">RED</option>
            <option value="black">BLACK</option>
          </select>
        </div>
          <div class="formLbl" style="width:84px;">&nbsp;</div>
          <button id="btnSave">Save</button>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Mayur,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      padding-left: 5px;
      color: white;
    .dojoxDock {
      display: none;
      border: #88165b;
      height: 25px;
    #entryDiv {
      padding: 8px;
      float: left;
    .formLbl {
      float: left;
    .formLine {
      width: 100%;
  </style>
  <script>
    let efp;
    require([
      "esri/Map",
      "esri/Graphic",
      "dojo/dom",
      "dojo/domReady!"
      let drawPnt;
        basemap: "streets",
        map: map,
        zoom: 12,
        view: view
        closable: false,
        resizable: true,
        dockable: true,
      efp.startup();
            weight: "bold"
        efp.hide();
          mode: "click"
        view.focus();
          efp.show();
  </script>
</head>
<body>
  <div id="viewDiv">
    </div>
      <div id="entryDiv">
        </div>
          </select>
        </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
